For everyone having trouble with there locks,radio,fuel door and trunk
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, For everyone having trouble with there locks,radio,fuel door and trunk in Past Cadillac Vehicle Discussion; So my catera was experiancing all of these problems not working i searchethe web some more and talked to a ...
    titan175 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    13
    So my catera was experiancing all of these problems not working i searchethe web some more and talked to a mechcanic and they both said to just unhook your aux water pump located on the passengers side all you have to do is dissconnect the wire harness and replace your # 10 fuse and all of these things should work for you.
    lakesidepark is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Catera
    Apr 2006
    Nashville TN
    172
    Re: For everyone having trouble with there locks,radio,fuel door and trunk
    wouldn't it be better to replace the faulty pump?
    Event3horizon is offline Cadillac Owners Member
    Sep 2008
    31
    8
    i dont understand what the "aux water pump" has to do with anything? And which fuse is fuse #10?
    Sep 2008
    13
    yeah you could replace it but i think there quite pricy, and if fuse 10 keeps blowing after you replace it try unplugging the pump and see if it blows after that
    disisjc is offline Cadillac Owners Member
    Jun 2007
    39
    And exactlly where is this pump, is it the part under the water res..?
    Apr 2006
    Nashville TN
    172
    I would replace it. Its not like it doesn't serve a purpose - your car will run hotter without it. Our cats don't need to run any hotter. I assume some think radio, trunk, fuel door, and locks are essential (and they are) however I would rather them fail and the pump keep pumping then the other way around.
  9. Remove Advertisements
