flywheel sourcing
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, flywheel sourcing in Past Cadillac Vehicle Discussion; Howdy, first time poster and forum noob. I am trying to find a bolt on flywheel for a 3.0 V6 ...
    malachi is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    44
    6
    flywheel sourcing
    I am trying to find a bolt on flywheel for a 3.0 V6 motor. I am making a new project and decided to go with one of these motors.
    Here is what I am starting with:
    1992 GEO Storm
    It currently has a an engine swap from a Oldsmobile Acheiva in it now. I used a Megasquirt ECM and built my own custom clutch from a Firebird. Car runs, but I decided to try something new.
    I picked up a 3.0 from a Saturn dealership some time ago with 60k. I have converted it over to the Catera intake so I could swap the intake inlet from the front of the motor to the rear of the motor to fit in my engine bay better. A lot of other small mods have been done for fitment.
    I am trying to decide if the COP from the Saturn motor or the coil pack from the Catera is better (read more reliable). I hope to incorporate both knock sensors, and the stock 60-2 trigger wheel.
    As I do not have the funds at this point to consider a twin turbo, I will be looking into a nitrous system once motor is fully running.
    The big hang ups right now, are the flywheel and time.
    The engine bolts up to my current transmission, and my stock Isuzu flywheel DOES bolt right up. However the crank diameter is smaller on the 3.0 and the Isuzu flywheel is a stepped design only ment to hold 160hp on a small 1.6 stock turbo engine. I can buy a fancier clutch to hold mrore power, but would prefer to just swap in a flywheel that has larger contact patch, and does not require a shim or hubcentric ring to center it. The only flywheels I have found were quite pricey and would require shipment from Europe.
    This engine will hopefully be running on a Megasquirt V3 once I build it.
    Finally, has anyone ever used a Megasquirt ECM on a Catera motor?
    MyOpel's Avatar
    MyOpel is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Y57XE
    Oct 2005
    Toronto
    203
    Re: flywheel sourcing
    the 3.2L motor (almost the same as the 3.0L) in the early CTS had a 5 speed manual as an option
    Sep 2008
    44
    6
    Yeah that was what I was looking into. 2003-2004 came up in possible years for me to look at. After that I got a whole series of other transmission codes, and I doubted they would apply to me.
    I'll try "car-part" and see what I find. I do not want to convert my car back to an automatic.
    This will make the 10th engine block installed into the car, and first of which to be a V6.
    All previous motors were I4, and most were turbo. The goal is just to try something that has never been done.
    thank you very much for the fast reply. I wish i could find the crank shaft spec for the bore size to find out if it will fit or not. (prior to buying one)
    Sep 2008
    44
    6
    Well the info above was 100% correct. The CTS does indeed bolt right up perfectly. It is a large flywheel though. Some sort of dual mass design.
    I bought one brand new for only $65 from a GM parts liquidator.
    I had to change the intake around to face the oposite direction, I plan to use the Saturn style timing belt layout rather than the Caddy version.
    I am machining out a spacer for the engine due to the thickness of the flywheel. So far things have gone very well in the thinking part of things.
    JRomano is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac Catera
    Nov 2008
    11768
    33
    144
    Megasquirt is a wonderful SEM
    I run my 16vT VW on Megasquirt n Spark extra
    Don't forget an Innovate LC-1 Wideband O2
    I cant say much about running a Catera engine on MS, but if its got a 60-2 crank trigger wheel you can use you'll be all set.
  8. Remove Advertisements
