Door lock fuse keeps blowing?
Results 1 to 11 of 11
Cadillac Catera and Cimarron Forum Discussion, Door lock fuse keeps blowing? in Past Cadillac Vehicle Discussion; Hello Folks, I'm having some electrical issues with my 99 Catera in which I hope someone can help. The primary ...
    Event3horizon is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    31
    8
    Hello Folks, I'm having some electrical issues with my 99 Catera in which I hope someone can help. The primary problem is my door locks, fuel door, and tunk do not work when the car is turned on due to the door lock fuse 20A blowing everytime I turn ignition on. When I take this fuse out of course i the locks, trunk, fuel door don't work. But when I turn off the car and put a health fuse on it works.. until of course I turn on the ignition and it blows. This is very frustrating.
    I've read about the Multi function control module and opened and inspected it and the cables on it but nothing seems odd. Fact is the first owner of the car replaced it around 47K miles (now it has 86K) So now would you think that its simply this module that is blowing the fuse? or something else.
    Thanks
    Sep 2008
    31
    8
    Re: Door lock fuse keeps blowing?
    jeez is this question really hard or just no one really cares to respond?
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    u got me stumped..... i've never had a problem like that. if you have a friend with a cat i'd swap it and see if they work. you checked all the soder points? they're reallyy hard to see even if they went bbaad. that's the best I can throw out there for you.
    Sep 2008
    31
    8
    thank you ahazard for the reply. I think the best thing to try is to replace that multifunction module again even though it has been replaced. I wonder if they go out more than once?? Somehow i'm skeptical that this is the problem. What i really need to get is a repair manual and study the cars electrical system so i can get to the root cause. I'll see.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Other GM cars would blow this fuse if tin foil or a dime were found in a lighter socket. Do all the cigarette lighters work? Have you removed the lighters and looked?
    Sep 2008
    31
    8
    Quote Originally Posted by carnut View Post
    Its an interesting tidbit, I checked the main lighter and it looks good and gives power to 12v accessories OK. I don't think there are any other hidden sockets i didnt see right?
    Jun 2007
    Mooresville, IN
    26
    677
    Quote Originally Posted by Event3horizon View Post
    there is one on the back of the main center console, right under the rear passenger vents (between the rear heated seate buttons if equipped on ur car). and the 2000 and 2001 have another to the left of the e-brake.
    Sep 2008
    31
    8
    alright well, i might have taken a shortcut fix, but i replaced the 20 amp fuse that kept blowing with a 30 amp and now all works fine. This car just has some BAD electrical issues.
    ichroque is offline Cadillac Owners Member
    Automobile(s): Catera 2000
    Oct 2008
    15
    I don't know if it's a good idea to replace a 20amp with a 30amp fuse. there is a reason why it's 20!!
    Which fusenumber is blowing?? #10?
    Feb 2003
    california
    69
    6,688
    Post back and let us know the extent of the dash fire.
    Oct 2008
    15
  14. Remove Advertisements
