All dash bulbs work except Oil pressure and Battery
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, All dash bulbs work except Oil pressure and Battery in Past Cadillac Vehicle Discussion; I have a 2001 Cat Sport. The Oil pressure & Battery Volt guage bulbs went out. Has anyone changed these ...
    01CadCat is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    Kent, Ohio
    45
    I have a 2001 Cat Sport. The Oil pressure & Battery Volt guage bulbs went out. Has anyone changed these before? Is it that hard of a job? And if possible the Part # of the bulbs? If not...that little area in front of them under the awning part of the dash would be perfect for a GPS.
    Much Appreciated Thanks!
    01CadCat
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Re: All dash bulbs work except Oil pressure and Battery
    They are pretty easy to change.
    Remove the vents in the middle. Remove the screw that holds the gauge cluster.
    There is also a screw right above the steering wheel column, so you have to remove that top column cover.
    There may be another screw somewhwre that I do not remember, otherwise, the panel is ready to come out. The bulbs come out with a 90 degree turn.
    There is also a thread on this, so look it up, 'cause i might have missed something.
    Good luck,
    Aras
    Aug 2008
    Kent, Ohio
    45
    Thanks R-Caddy
    R-Caddy's Avatar
    Jul 2005
    Savannah, GA
    32
    698
  7. Remove Advertisements
