Catera..... Need help!!!
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, Catera..... Need help!!! in Past Cadillac Vehicle Discussion; Hi, I have a 98 catera and recently there's a minor leak by the driver's side rear end by the ...
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Hi,
    I have a 98 catera and recently there's a minor leak by the driver's side rear end by the exhaust. I think it may be a coolant leak but no idea from where it is coming from. I cannot see any leak from the top of the engine........... and I have posted some pictures below so you could see it. Any ideas what it could be and recommendations?
    http://i513.photobucket.com/albums/t...8/P1030448.jpg
    http://i513.photobucket.com/albums/t...8/P1030449.jpg
    http://i513.photobucket.com/albums/t...8/P1030451.jpg
    http://i513.photobucket.com/albums/t...8/P1030461.jpg
    http://i513.photobucket.com/albums/t...8/P1030454.jpg
    Thanks.
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Re: Catera..... Need help!!!
    Looksa little bit like oil to me. Is your oil OK? That Heater Valve can be one of the causes.
    Sep 2007
    1,024
    I changed the heater control valve few months ago. I think its coolant because I can see few drops dripping down when I have the car in the garage and it is not as thick as oil but I could be wrong or maybe leaking from the hose that is hooked up to the heater valve. I'll have to check it out and see if there is any hose leak. But also looks like oil on the transmission body.
    Thank you.
  5. #4
    Army_MP_From_MO's Avatar
    Army_MP_From_MO is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac
    Mar 2008
    El Paso, Texas, United States
    44
    240
    Is it ATF?
  6. #5
    R-Caddy's Avatar
    Jul 2005
    Savannah, GA
    32
    698
    I still say it's the Heater Valve. I have replaced 2 in mine this year...
  7. #6
    Sep 2007
    1,024
    I haven't checked it yet and I think it is anti-freeze.
  8. #7
    Mar 2008
    44
    240
    Might be the thermostat
  9. #8
    Boris is offline Cadillac Owners Fanatic
    Sep 2005
    Florida
    188
    If you are sure that it's coolant than I would remove the intake manifold (upper and lower) and check your engine oil cooler cap.
    If it's all dry at the cap and by the top of the head than I would closely check the metal oil cooler lines. Remove the coil pack that is behind the head for a closer look.
    Mine looked identical to what you showed in the pictures but I was sure it was oil. Ended up being a head gasket.
    Head was slightly warped and the gasket let go. Didn't need a lot of milling and a new gasket solved all issues.
  10. #9
    Sep 2007
    1,024
    SmileRe: Catera..... Need help!!!
    How easy is it to get everything out? If you have instructions that would be awesome!!!
  11. Remove Advertisements
