Serpentine belt and tensioner?
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Serpentine belt and tensioner? in Past Cadillac Vehicle Discussion; Hi Guys!!! I'm curious to know how easy is it to replace the serpentine belt and tensioner on 98 catera. ...
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    SmileSerpentine belt and tensioner?
    Hi Guys!!!
    I'm curious to know how easy is it to replace the serpentine belt and tensioner on 98 catera. I see some cracks on the belt and wanting to replace it. Any tips or suggestions and what tools are required to do the job? If you have any pictures on how to do it that would be awesome!!!
    Thank you.
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Re: Serpentine belt and tensioner?
    Hi. I've done it a couple times. It's pretty easy. You will need a 15mm wrench for the pulley. Remove the intake elbows that go to the throttle body. Remove the AIR, as they call it, line fitting- it's the aluminum tubing behind the intake plumbing, it has a 3-4" rubber hose piece held by hose clamps on it to slide the belt through, somewhere between water pump and power steering pump. Everything is pretty much straightforward. There may be another bolt or two to be removed, but that's about it. It should take you 15 or so minutes.
    Good luck
    Sep 2007
    1,024
    SmileRe: Serpentine belt and tensioner?
    Just to give an update!!!!
    Replaced the serpentine belt & pulley, was very easy than I thought. It took about an hour.
    Thanks.
