Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: 3.2 swap and 0411 code
Old 08-17-08, 08:26 PM
Cadillac(s): Cadillac
View cjs5t's Photo Album
Casino Cash: $285
Post 3.2 swap and 0411 code
hi everyone -
i have a 2001 catera. recently, the engine blew, and i sourced out a 3.2l for a great price. i had a local mechanic install it.
since then, the 0411 - secondary air injection code has been pulled several times and reset. after some frustration, i dragged the car to a cadillac dealership. they got the pump working, but they explained that the reading was low - air pressure maybe - and while they took their pound of flesh, they weren't keen on delving into the problem past a few hundred in labor.
i know that some people have claimed to pull off this swap. my question is whether this could be related to using the 3.0 computer for the 3.2 engine, or whether there is a common solution to what seems to be a nightmare problem - vacuum hoses, 'check valves' sticking, and an unreliable air pump.
i'd appreciate any help that you all can provide. thanks.
  #2 (permalink)
Old 08-18-08, 05:57 PM
View passionaterage's Photo Album
Casino Cash: $1740
Re: 3.2 swap and 0411 code
Now this may or may not help you, but I have a Camaro that I just had the same problem with. I thought it was the pump, but it turned out to be one of the check valves. And I was also getting the 0411 code. It was allowing air thru, but only about half as much as it should. The check valves would be the very first thing I would try, as they're usually fairly cheap. Only 10 bucks apiece for my Camaro, so shouldn't be over like 80 for the catera...lol
  #3 (permalink)
Old 08-19-08, 07:45 PM
Casino Cash: $285
hey it can't hurt - well except for buying the part. thanks for the tip.
  #4 (permalink)
Old 08-21-08, 01:06 AM
View Warez's Photo Album
Casino Cash: $2531
The 0411 code can actually be several components including the MAF. I highly doubt that it has anything to do with the 3.2 engine.
It is possible that the air pump was never the problem. You should not have paid the dealer since they did not fix the problem. You should take them to small claims court to get your money back.
I have this dreaded code as well.
BTW how did the original engine blow?
  #5 (permalink)
Old 08-21-08, 04:15 PM
View MaesMV6's Photo Album
Casino Cash: $3710
never did the swap, but this was my problem about a month ago
this is what i found. 90% of the time its the check valve reeds sticking. pull it off, spay carb cleaner though it and see if it pulls the code again. this was the fix to my problem. on the forums somewhere (search for p0411) there's maybe 10 posts about it, but there is a good read on how to check all your parts on the secondary air injection system without having to use a tech 2 tool. could be the pump, there are 2 valves (one plastic and one metal (metal is check valve im talking about)) and there is a control solenoid that tells the plastic valve when to open/close. if all those are fine it would be a vacuum line somewhere.
its just an emissions things, car will run great without it. all it does is remove the emissions from the exhaust until the cat converter is warmed up. at least thats what they told me
  #6 (permalink)
Old 08-22-08, 04:56 PM
Casino Cash: $2531
Where is the valve that you cleaned located?
  #7 (permalink)
Old 09-01-08, 04:34 PM
View Black02SLPSS's Photo Album
Casino Cash: $2910
This is a little off topic, but how does that 3.2 feel in comparison to the 3.0? The 3.0 in my caddy blew up and im looking for new engines or converson options so im curious. Thanks
  #8 (permalink)
Old 09-03-08, 03:48 PM
Casino Cash: $3710
sorry its taken me so long to reply, hopefully you have it figured out. #3 in this picture is the check valve im talking about
http://www.cadillacforums.com/forums...2&d=1133439697
its a metal valve right in front of the engine when you look under the hood. some what of a pain to get it off, but it was a hell of a lot cheaper then to go pay for it. here is how i figured out what was wrong, its a long read but definately worth it if you don't have a tech 2 tool
(last post)
http://www.cadillacforums.com/forums...jection-2.html (Code 0411 Secondary Air Injection)
Tags: , , ,
0411, code, swap
