Thread: Water4Gas HHO?
- 08-11-08 11:13 AM #1
Cadillac(s) I Drive: Cadillac
- Join Date
- Aug 2007
- Posts
- 8
Water4Gas HHO?
Has anyone tried installing one of these on a Catera yet? I'm curious to know.
Thanks!
J
Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.- Join Date
- Always
- Posts
- Many
- 08-11-08 11:43 AM #2
Re: Water4Gas HHO?
There were several threads concerning this scam, down in Seville and Northstar Perfromance, a couple of months ago.
(I have a bridge in NYC that I will sell cheap, also.....
- 08-11-08 11:57 AM #3
- Join Date
- Oct 2007
- Posts
- 260
Re: Water4Gas HHO?
Theoretically it does work.
but mostly what are sold now for under $500 are pretty much scams.
the way it works is if you heat up your fuel and inject hydrogen you can go for about 15 AFR at crusing to about 30 AFR, pretty much doubling your fuel efficiency.
but good luck trying to get the computer to inject half the fuel it's programmed to do (that'll be a project on it's own). and not to mention trying to keep the water from freezing (if you live anywhere that goes below freezing.)
- 08-11-08 01:09 PM #4
Cadillac(s) I Drive: 92' Eldorado, 97 Catera
- Join Date
- Dec 2006
- Location
- Tennesse
- Posts
- 289
Re: Water4Gas HHO?
Yes they work. I have built and installed two systems on two different cars. Both still run fine and have seen an increase if fuel economy. Don't fool yourself into thinking you can double your gas mileage (at least not in any modern engine). It is not possible. Your pistons would melt in the cylinder running that lean. That is if your catalytic convertor didn't melt first.
I have not installed one on a Catera yet. I actually started to post a write up on this site last week. I decided against posting it until I came up with something more pleasing to the eyes. Next week I should be done and have it installed. I will post what I did and the results good/or/bad. I seen no reason that they will not be good based on my other installations.
- 08-11-08 07:12 PM #5
- Join Date
- Aug 2007
- Posts
- 8
Re: Water4Gas HHO?
Cool. Please let me know your results. I can get a MAP/MAF sensor controller to regulate gas flowing into the intake too so that should solve that problem. I'm going to do thorough testing in another vehicle first though. I'm in FL so no need to worry about anything freezing.
- 08-22-08 01:53 AM #6
- Join Date
- Dec 2006
- Location
- Tennesse
- Posts
- 289
Re: Water4Gas HHO?
Sorry JJHatcher, didn't mean to leave you hanging. My two days off this week turned into two 12 hour days. I will post some info on what I did this weekend when I have some time to take pictures in day light.
- 11-24-08 02:22 PM #7
- Join Date
- Jun 2007
- Posts
- 39
Re: Water4Gas HHO?
This has been a really long weekend
- 11-24-08 04:23 PM #8
- Join Date
- Jun 2005
- Posts
- 484
Re: Water4Gas HHO?
If this is the device that produces hydrogen then it is indeed a scam and it is completely 100% impossible to improve your fuel economy by using this.
Mythbusters also dubunked this device in an episode, predictibly it decreased fuel economy as well.Last edited by Warez; 11-24-08 at 04:34 PM.
- 11-24-08 09:35 PM #9
Re: Water4Gas HHO?
.........absolute, positive snake oil. This scam has been around since I was a kid and it hasn't changed in 55 years. Curious that every automobile manufacturer on earth, as well as NASCAR, isn't using the principle. As P.T. Barnum observed: "There's a sucker born every minute."
- 11-25-08 08:06 AM #10
Re: Water4Gas HHO?
So I guess if you dont know much about engines you can come up with some very interesting theories...
I wonder how much electrical current it takes to make the hydrogen and exactly how much hydrogen you end up making... I know an engine runing at idle for 1 min absorbs as much air as it takes for a human to brathe 8min... and thats assumed small type engine, not a V8 or nothing of that sort...
And also engines are running at around 98% combustion efficiency so I dont see how with this hydrogen device you can get any better then that...
If you want to see some real improvement in MPGs here are a few tips...
Keep your tires overinflated by 2-3 PSI... The catera specifies 32 I beleive, I run them at 35 city and 38 hwy and I can tell a difference.
Run 5W30 instead of 10W30 < Helps qutie a bit ~1mpg...
Make your car more aerodynamic... chin spoiler and perhaps close off some of the openings on the grille... I hear clear tape around many of the gaps around the bumper will help.. .it might look like poop but if you are after MPGs and not looks then this would work..
Get AAA card or something of that sort and get rid of your jack and spare tire for a good weight savings...
Make sure your brakes are properly adjusted so that there is no friction that will rub off fuel economy.
Change your Air and Fuel filters... and maybe even get a different set of mufflers for the car as those will also free up breathing space for the motor and make it sound a bit better...
Those are just a few that I can think of off the top of my head...
Another thing I heard was an additive that was added to the coolant and it allowed for better heat transfer and thus allowing the motor to run cooler which should help some except too cool and then the engien thinks its not warm enough and ends up increasing the air/fuel to try to bring it up to temp...
In fact my car lately with the cold weather has been keeping between 177 and 184... I guess the thermostat doesnt even open!...
Ahh also try to keep unnesesary power devices turned off... like your headlights during the day... etc those suck power too and make your alternator work extra hard to keep up...
And finally its all about how heavy your foot is, and if you wanna fix that take a piece of 2x4 and stick it behind your gas pedal... that alone will be worth 3-4mpg...
Me driving like a granny I get 23 around town... if I drive like I stole it its more like 15... see the difference?
Same deal goes for hwy use... I have seen as high as 28mpg... and as low as 19...
Ave is around 21 and varies by +/- 1mpg based on oil used and tire pressures...
| Sponsored Cadillac Advertisements (Supporting Members don't see these ads): | |
LinkBack URL
About LinkBacks
