Water Pump Replacement
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, Water Pump Replacement in Past Cadillac Vehicle Discussion; 2001 Catera Sport Started slowly losing coolant. Intermitant cooling issues. Drone coming from area of water pump, and signs of ...
    wildrage is offline Cadillac Owners Member
    Automobile(s): 2001 Catera Sport, 1993 Cadillac Eldorado Touring Coupe (N*)
    Dec 2006
    Bridgewater, NJ
    35
    92
    2001 Catera Sport
    coming from area of water pump, and signs of coolant leaking onto
    flywheel and pooling at front of engine.
    Looks like a no-brainer. Here's my question: Do you NEED to replace
    the timing belt when you do the water pump? I know it's a good idea,
    but I don't have the money or the tools to do it right now.
    cateraowner is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Oct 2007
    260
    Re: Water Pump Replacement
    doesn't look like you have to replace the timing belt. alldata makes no mention of any special tools either
    REMOVAL PROCEDURE
    -Disconnect the negative battery cable.
    -Drain the coolant.
    -Remove the intake air resonator chamber.
    -Remove the front timing belt cover.
    -Remove the water pump bolts. Important: Use a catch basin to prevent the escaping coolant from contacting the timing belt.
    -Remove the water pump.
    -Clean the cylinder block sealing surfaces.
    INSTALLATION PROCEDURE
    -Coat the seal ring of the water pump with silicone grease, GM P/N 12345579 or equivalent.
    -Install the water pump.
    -Install the water pump bolts.
    -Tighten the water pump bolts to 25 Nm (18 ft lbs).
    -Notice: Refer to Fastener Notice in Service Precautions.
    -Install the front timing belt cover.
    -Install the intake air resonator chamber.
    -Refill the cooling system and bleed the cooling system.
    -Reconnect the negative battery cable and reprogram the applicable accessories.
    Dec 2006
    Bridgewater, NJ
    35
    92
    Yeah, that's what I read in Alldata as well. Maybe you or someone hear can clarify something for me.
    Everything I've read says that the water pump is timing belt driven. Is that correct? The serpentine belt diagram under my hood shows the belt going through the WP, which I'm assuming is the water pump. Are both belts involved? I'm confused. I guess everything will make sense when I take it apart...
    frank moran is offline Cadillac Owners Fanatic
    Automobile(s): Catera, ..
    Jan 2007
    canton,ga.
    72
    231
    Quote Originally Posted by wildrage View Post
    The WP is serp belt driven, just cover the T belt to keep coolent off it when you pull the pump off, there may still be some coolent present unless you do a good job of draining the rad....
    Dec 2006
    Bridgewater, NJ
    35
    92
    That's what I thought! On the Autozone site there's a note that says "Pump is timing-belt driven, timing belt replacement recommended."
    Thankfully I ordered a new one directly from a dealer - only $35
    Thanks for the help!
  8. Remove Advertisements
