dexcool vs conventional?
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, dexcool vs conventional? in Past Cadillac Vehicle Discussion; well i have the engine almost back together in my 97 catera after replacing the oil cooler. the parts came ...
    Jamies97Cat is offline Cadillac Owners Member
    Automobile(s): Cadillac Catera
    Jul 2008
    Tarpon Springs FL
    40
    31
    well i have the engine almost back together in my 97 catera after replacing the oil cooler. the parts came in today and all i have left to do to the car is put the radiator, fan, and hoses and a few plugs and air box back in. my question is, since my block is totally drained of coolant and all the houses are too, can i put green coolant in the car. i know gm says use dexcool only but why, what the hell is the difference. i want to fill it up and drive it for about 500 miles and flush it again to get any left over sludge out of it so i didnt want to spend a small fortune on dexcool just to waste it soon. would it be wise to put green coolant in it? thanks for any info.
    cateraowner is offline Cadillac Owners Fanatic
    Oct 2007
    260
    Re: dexcool vs conventional?
    I don't know what the difference is, just seems like gm's way of making more money.
    I can't see a problem of putting regular coolant in as long as you are 110% sure all the coolant is drained. I heard that the 2 coolants turn corrosive when mixed.
    another suggestion, since you're only driving it 500 miles and flushing it again, use only distilled water, or a 20-80 mix.
    retho78 is offline Cadillac Owners Connoisseur
    Sep 2007
    1,025
    SmileRe: dexcool vs conventional?
    I have been using the conventional coolant in my catera for two years and so far no problem. I flushed out the dexcool first and using the supertech brand (all vehicles)from walmart.
