Results 1 to 4 of 4
Thread: How to disable the leveling system?
    Jul 2006
    39
    Hi, I just bought GTO shocks from R-Caddy and should be getting them pretty soon. The only thing I'm worried about is having the leveling light flashing the whole time after I install the new shocks. I've been reading about many different methods of dealing with this: taking the bulb out of the dash, manipulating the lever arm, and pulling out the relay. But there is no good/detailed set of instructions on how to do each of these things. Can anyone tell me the best way to deal with this and how to do it?
    Thank you,
    Long
    Jul 2006
    39
    Re: How to disable the leveling system?
    bump
    cateraowner is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Oct 2007
    260
    I don't know how to deal with the lever arm, what I did was take the bulb out. just pull the cluster and remove the bulb from the back.
    I also want to disable the pump since it has no reason to go on.(I'm under the impression that the pump's only purpose is the shocks)
  5. #4
    Jul 2006
    39
    Thanks for the reply, it would be nice to get rid of the pump if it wasn't doing anything. I was looking at the relays and I got the impression that the leveling relay also served many other functions so I don't think I'm going to mess with it.
  • You may not post replies
