weird ac/heat problem?
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, weird ac/heat problem? in Past Cadillac Vehicle Discussion; hey guys, been experiencing another problem with my 01 cat recently. this time not radiator related. when summer came around, ...
    blue_wrx2003 is offline Cadillac Owners Member
    Jan 2006
    9
    hey guys,
    been experiencing another problem with my 01 cat recently. this time not radiator related. when summer came around, i tried turning the climate control down to 60 and found it was blowing really hot air, like the heat was on. however, when i turn it up to 90, it blows out semi decent cool air. the passenger side however is fine. i don't get it? i tried unplugging the battery for a while but nothing worked. any ideas? thanks!
    ~Dennis
    callingmonroe's Avatar
    callingmonroe is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS4 2010
    Mar 2008
    Richmond, Virginia
    57
    Re: weird ac/heat problem?
    I noticed yesterday, mine did the same for about 5 min. The fan speed was on low and temp was set at 68, BTW I would not try going lower than that, it could never achieve it anyway. But it was strange anyway I turned off then on again then kicked the fan on high and it started working, maybe your compressor is not kicking on, or low on freon due to leak.
    lakesidepark is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Catera
    Apr 2006
    Nashville TN
    172
    driver's side screwed, passenger side works fine? check the vent door actuators, search this forum and there is a short writeup on how to get to the screw that loosens on the gearmotor and causes it to just flap around. Then you will have to re-sync the actuators.
    Jan 2006
    9
    Quote Originally Posted by lakesidepark View Post
    thanks for the response guys, however i tried searching and couldn't find a good write up on it. any help on a link? thanks again!
  7. Remove Advertisements
