Results 1 to 3 of 3
Thread: Instrument Panel Problem
    CaddyMD is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    My far right instrument panel does not work fully. But the weird thing is once i turn the key and little past start and do not start the car they work. Any explanation for this is their a way to fix this?
    This is what come on the battery light,security,leveling lights. The thing is once i turn the key a little past start everything comes on and work but not fully as oil pressure and battery voltage are wrong. I checked the oil pressure it right below max and battery is brand new and works fine. Anybody else had this problem?
    Army_MP_From_MO's Avatar
    Army_MP_From_MO is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac
    Mar 2008
    El Paso, Texas, United States
    45
    240
    Re: Instrument Panel Problem
    Everything else work? fuel door, trunk release? Check them before you turn your key past start
    szaeske is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Catera
    May 2008
    St. Louis, MO
    47
    40
    I just had the exact same problem, but it is a bit of a stickler to diagnose. Here is where you need to be careful: There are three pieces/parts that can be your problem...the ignition switch itself (not the cylinder), which is connected to a housing, which is then connected to the lock cylinder. These are a bit of a pain to work on as you need some fairly special tools and it can be a bit dangerous as you are working on or near the airbag system on the steering wheel.
    If you mess with the key in the ignition while the car is running and you can intermittently get the oil press and voltage gauges to work, then one of these three components is your problem.
    I started by replacing my ignition switch because it was the easiest to get to and was available at the salvage yards. This lasted a while before it started again. At the same time, it started getting more difficult to turn the key once i inserted it in the ignition, so i started asking some more questions and was told the housing or cylinder could be the problem. I was also told by a few techs that the ignition cylinder is another fairly common catera problem. I took things apart again and noticed i may have ruined one of the lock tabs on the ignition switch housing when i replaced the switch, so it wasn't getting a good connection.
    Until i get the money and time to get the parts fixed, i was able to fold a piece of duct tape a few times and wedge it in between the steering column cover and the end of the ignition switch to keep the switch pressed into the housing. I am not advocating fixing things this way, i am just saying it works for me on a temporary basis until i get to fixing the cylinder and housing.
    I may have to just go to the stealership anyway in order to have them reset my tumblers on the new cylinder to match my key. I asked one of the stealerships if i could bring in a cylinder from a salvage yard and have them reset the tumblers and they said no because of the GM anti-theft key policy, but maybe i just asked the wrong person. Another tech may say yes....hopefully.
    thanks,
    scott
  • You may not post replies
