Vents blow hot air after AC
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, Vents blow hot air after AC in Past Cadillac Vehicle Discussion; After I would turn off the AC, the vents would start to blow hot air (like when the car is ...
    Lawrence_C is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    70
    After I would turn off the AC, the vents would start to blow hot air (like when the car is just blowing vented air). It isnt blowing at a fast speed, but it would make the car so much hotter. Is this due to the result of the vents not closing properly?
    Also, after im exiting off the highway, the oil light (orange) would appear. It would stay there for a minute or so and then go away. Nothing appears to be wrong with the car but it does get annoying. Any ideas?
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Re: Vents blow hot air after AC
    My vents also blow air, so I assume that is the normal behavior. My oil light comes on if I start running low on oil. That usually happens on the highway, but still a good indication. Just top it off.
    xanax06's Avatar
    xanax06 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Catera
    Jan 2008
    Philadelphia
    144
    Mine does this also. I roll the vents closed, but it doesnt help much.
  5. #4
    gunther1000 is offline Cadillac Owners Fanatic
    Mar 2008
    Nashville
    183
    In my travels I think all GM cars of this time frame do that. I think the only thing you may want to look for is a vacume leak. If it doesnt switch from vent to defrost to floor very well then I would keep on looking till you find a leak in the system some where. Someone else may be of more help on this and the Catera vents may even be electric but I did have a Grand Prix that had a problem moving from defrost to vent and it was a vacume leak.
    That said, My car does the same thing but not anymore that other GM cars I have had. I always hate it and think it could be easily fixed in there design over the ears. When I say OFF I want OFF! not Gentle Breeze.
    my .02
  6. #5
    jurias is offline Cadillac Owners Member
    Jul 2008
    1
    what is the easiest way to check for a leak and where should i look for the leak? by the fire wall?
  7. Remove Advertisements
