| Re: Car does not crank... First of all... cursing us out because you dont get an answer is the wrong way to go about this.
Secondly, what voltage is the battery reading? How many amps? Get the battery tested. Does the starter actually work or does it just click? It could be the starter or a bad battery. It could be a bad ground. Check the connections on the battery itself if its corroded, clean it.
Thirdly (if above does not apply), are you getting fuel and are you getting spark if none of the above are true? Can you verify the fuel pump is turning on and the sparkplugs are firing off?
__________________ Feels kinda blistery in here, anyone else feel that? Oh waits its me. |
