lowering catera
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac Catera and Cimarron Forum Discussion, lowering catera in Past Cadillac Vehicle Discussion; I have a 98 catera and want to lower my car. Intrax is the only company to make springs for ...
    rchurchman2002 is offline Cadillac Owners Member
    Nov 2003
    33
    lowering catera
    I have a 98 catera and want to lower my car. Intrax is the only company to make springs for this vehicle which drops about an inch to a half. Im wondering if this car will require a camber kit? If so, where do I get one for the catera. Also, how will the automatic leveler system wortk with lowering springs?
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Re: lowering catera
    Quote Originally Posted by rchurchman2002
    If you do springs, you'll want to do new shocks too...
    Intrax makes camber kits but apparently not for the Catera. If it does need it, this may be one solution: http://www.ingallseng.com/cars/cadillac.html They only make the adjusting bolts for the front because the rear is non-adjustable. Plus the rear is already at a pre-set positive camber.
    If you get new shocks, you'll have to disable the system somehow OR get passive shocks from this company: http://www.cadillacstruts.com/ This requires calling them, they will make you a pair for your vehicle.
    Nov 2003
    33
    Re: lowering catera
    I called cadillacstruts.com and they have nothing for the catera nor know anything about their suspension system. Anymore ideas?
    If i just put the lowering springs on and a front camber kit, what will the auto leveler do?
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: lowering catera
    IF the springs lower it enough, theres a possibillity that it may engauge the compressor, and when it cant raise the car up it will continue until it breaks. Or if its smart, it will shut itself off automatically and start showing an error code.
    If its strong enough it'll raise the car up to its preset hight, and then it wont be lowered.
    xxxxxxx is offline Cadillac Owners Member
    May 2004
    33
    Re: lowering catera
    I had a set of intrax springs on my catera before bagging it. The camber got really bad in the back I burned through 4 new tires within a month and a half
    I dont think it messed with the leveling system since it was only a couple inches but I cant remember for sure.
    oserus98 is offline Cadillac Owners Member
    Apr 2004
    New Haven, IN
    37
    22
    Re: lowering catera
    Is there anyway to adjust the camber in the rear if lowered? Or will you have to burn through the tires?
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: lowering catera
    From what I read on the website, theres no way of adjusting it physically (with say, adjusting bolts) unless you get new control arms... which i cant seem to find.
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: lowering catera
    Using an example from a user (named Catera) who joined recently, he has an Omega...
    http://www.cadillacforums.com/photop...20back-med.jpg
    Thats what we call a tire burner... im not sure what hes done suspension wise (it is lowered) but... lol, thats extreme.
    Apr 2004
    New Haven, IN
    37
    22
    Re: lowering catera
    What about the front? Is it required to replace the struts with shorter struts if you're only lowering it 1.5"? Sounds like it may not be worth it with all of the little gotchas.
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: lowering catera
    There are companies that make aftermarket shocks for the Catera (like there is for every vehicle) , who knows if you need shorter ones... 1-1.5 inches doesnt seem much for the shock...
    rbanda's Avatar
    rbanda is offline Cadillac Owners Member
    Jan 2004
    CALI
    34
    51
    Re: lowering catera
    hello all... i have a 99 catera. i always thought about lowering it but just didnt like the fact that it was only going to lower it 1.5". So i decided to put it on a airride system. here is the direct link to my car. http://www.cardomain.com/member_page...ll_action=view
    guinngd84 is offline Cadillac Owners Member
    Re: lowering catera
    Quote Originally Posted by rbanda
    where did you get the grill for the catera
    rbanda's Avatar
    Jan 2004
    CALI
    34
    51
    Re: lowering catera
    Quote Originally Posted by guinngd84
    at a cady aftermarket producer. they recieve alot of cadillac cars and trucks from the dealers and fix them up... ill see if i can find one for you
  16. #14
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: lowering catera
    http://www.egclassic.com/grillecadillac.htm
    E & G Classics makes one or two grills for the Catera.
    If you want to get one thats more "racy" looking, you can go to a company that makes em for the Omega (the orignal car)...
    http://www.irmscher.de/int_zp/index.php?clicka=1
    and http://www.irmscher.com "Accessories Programme> Omega > till or from 1999, depending on your model"
  17. #15
    rbanda's Avatar
    Jan 2004
    CALI
    34
    51
    Re: lowering catera
    not anymore. they stoped productions when i called back in early 2004 for the lower grille but that was early this year
    Quote Originally Posted by JefferyG
  18. Remove Advertisements
