Results 1 to 3 of 3
Thread: Sluggish Acceleration/Idling
    kamorgan is offline Cadillac Owners Member
    Automobile(s): Cadillac Catera 2001
    Jun 2008
    48
    4
    Hello all. I drive a 2001 Catera with just over 72K miles on it. I bought it about 3 months ago and it has been running great besides an occasional high idle when started in the mornings but goes away. I filled my tank this morning on the way to work and about 2 miles later while on the freeway when I went to accelerate or had my foot on the gas, the engine began riding rough (sputtering). The check engine light came on two days ago but usually goes off after I filled the tank or open the gas cap. Car will accelerate fine but its just sputtering getting up to speed. Once I parked the car was still idling rough. Any suggestions on what could be going on and what needs to be done to correct this situation? Thanks for any help any of you could give.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Sluggish Acceleration/Idling
    The fast idle is normal. It heats the oxygen sensors quickly to reduce emissions. Take the car to AutoZone or most any parts store and they will read the Check Engine Light codes for free.
    The rough idle could be due to contaminated fuel. Most common is water. It doesn't bond with gasoline but it will mix with it through normal agitation. This mixture is heavy and sinks to the bottom of the tank where the fuel pick-up sucks it in. Since it doesn't bond with gas this water enters the cylinders in uneven concentrations. Water does bond with alcohol, which in turn bonds with gasoline.
    Add a bottle of an isopropyl alcohol based fuel treatment like Iso-Heet to your tank. Any water will be absorbed be the alcohol and burned off through combustion.
    When the tank is close to empty refill with fuel (from a different station) and add a bottle of Techron fuel treatment to clean the injectors. I've used this on my motorcycle with good results. I use it in my Catera also but since she's never shown any rough running or stumbles I can only assume the Techron is keeping things clean.
    Beyond that you could have a dirty Mass Air Flow sensor. Search the archives for more info.
    Elvin
    Jun 2008
    48
    4
    Thanks for the advice. I will do that as soon as I leave work today.
  • You may not post replies
