| Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron. | Cadillac Forums: Has all electrical but Won't start when hot
06-05-08, 12:56 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Has all electrical but Won't start when hot So on a hot day, if I make a stop after the engine has heated up, sometimes it won't start again. I get all the dash lights, radio works, interior and headlights (if night) all work but no ignition. No solonoid click, nothing. I let it sit awhile and it will eventually start. Opening the hood shortens the waiting so I assume it is something overheating.
I have replaced the battery and both coil packs. Any suggestions? |
07-18-08, 10:14 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Mar 2008 Location: Nashville | | | Re: Has all electrical but Won't start when hot Shoot this problem either has all you Super smart Catera lover stumped or its just such a simple question you dont grace it with your response...
There must be 5 post with not one clue as to what this gremlin could be...
Great |
07-19-08, 12:10 PM
| | Cadillac Owners Member Cadillac(s): 99 Deville concours | | Join Date: Aug 2007 Location: oshkosh,wi Age: 39 | | | Re: Has all electrical but Won't start when hot Quote:
Originally Posted by Searayjba So on a hot day, if I make a stop after the engine has heated up, sometimes it won't start again. I get all the dash lights, radio works, interior and headlights (if night) all work but no ignition. No solonoid click, nothing. I let it sit awhile and it will eventually start. Opening the hood shortens the waiting so I assume it is something overheating.
I have replaced the battery and both coil packs. Any suggestions? | Starter? |
07-20-08, 01:38 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Has all electrical but Won't start when hot Quote:
I have replaced the battery and both coil packs. Any suggestions? | OMG!!! I cannot believe this is happening to someone else in the exact same manner. Except we take the cap off the water tank too to shorten the time even more. It usaully takes about an hour to start. I can't figure it out for nothing. We've had everything changed but nothing has stopped this behavior. My car doesn't exactly run hot but it does get a little above the half line sometimes, and it won't start until the engine cools down. Some people have told me that Cadillacs have a very intelligent sensor. It doesn't allow the car to start until a problem has been fixed. I don't know how true that is, so i'm going to my mechanic to have him check it out. The only thing though is that i have to bring my car to him while it's doing this, so i have to drive it for a while then bring it ti him a shut it off so he can see himself. HMMM Crazy!!! I should just be able to tell him what's going on and he can diagnose it that way. Anyway, let me know if you have figured out anything so i can get this fixed on my car as well. Thanks |
07-20-08, 03:46 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Mar 2008 Location: Nashville | | | Re: Has all electrical but Won't start when hot My car will without fail do it mid day everyday this summer at lunch time when it is most hot out in Nashville. But it starts fine in the morning and evening! im talking about a 10-15 degree change in weather and boom its running. mid day and you are stranded.....
Answer me this and you get a gold star!!!
Many have swaped batterys and starters in this mystey..... HELP US!!!! |
07-21-08, 09:15 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | Re: Has all electrical but Won't start when hot It could be the CPS!!! |
07-21-08, 09:27 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Has all electrical but Won't start when hot I agree, could be the CPS. Alot cheaper than the coil packs and starters
Good Luck |
07-21-08, 11:25 PM
| | Cadillac Owners Fanatic Cadillac(s): Catera, .. | | Join Date: Jan 2007 Location: canton,ga. Age: 65 | | | Re: Has all electrical but Won't start when hot My first check would be the battery cables, especially the positive one, check the ground also. The next time you have it running awhile feel the temp of the positve, if its too hot to touch you have a high resistance situation, my problem was in the actual positve cable lug. A new battery cable end solved it, the old cable had a .6 volt drop. Bottom line the battery was not up to full charge. Also on the more current models if there is a charge problem check the wire from the starter to Alt for corrosion.... the coils and CPS don't come into play until the engine is turning over...hope this helps. Quote:
Originally Posted by gunther1000 My car will without fail do it mid day everyday this summer at lunch time when it is most hot out in Nashville. But it starts fine in the morning and evening! im talking about a 10-15 degree change in weather and boom its running. mid day and you are stranded.....
Many have swaped batterys and starters in this mystey..... HELP US!!!! | |
07-21-08, 11:34 PM
| | Cadillac Owners Member Cadillac(s): 2001 Catera | | Join Date: Jul 2008 Location: PA | | | Re: Has all electrical but Won't start when hot CPS is a cheap fix and cheap to rule out as a suspect |
07-22-08, 01:52 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Mar 2008 Location: Nashville | | | Re: Has all electrical but Won't start when hot Quote:
Originally Posted by Yose CPS is a cheap fix and cheap to rule out as a suspect | Great, now what is a cps and where is it located? Thanks. |
07-22-08, 02:02 AM
Originally Posted by gunther1000 Great, now what is a cps and where is it located? Thanks. | And if all of you are saying a crank shaft position sensor IM GOING TO SCREAM!!!!
How can it possibly be a sensor if the car makes NO attempt to even turn over? We are talking about no power to the starter what so ever. not a non running car that cranks and cranks. No attempt to try to start what so ever with full power to everything but the starter only some times. Like and mostly when hot out. mid day 80-90 degree weather and no clicks no slow crank and then clicks nothing at all!
But full power, great charge/new battery, new starter and not a single thing untill hours later and outside temps drop ever so slightly. I have been dealing with this for 2 months and it really sucks. A very reliable car once started but getting it there has become like playing the lotto on a warm day.
COME ON HELP!!!!!!
ANY TECHS OUT THERE?
PLEEEEEEEEASE
07-22-08, 10:06 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Has all electrical but Won't start when hot Its a crank position sensor located under the car near the oil filter. It cost around $40.00 for the sensor. |
07-22-08, 10:40 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Mar 2008 Location: Nashville | | | Re: Has all electrical but Won't start when hot did you read my post? Are you on drugs? |
07-22-08, 01:32 PM
| | Cadillac Owners Fanatic Cadillac(s): Catera, .. | | Join Date: Jan 2007 Location: canton,ga. Age: 65 | | | Re: Has all electrical but Won't start when hot Gunther, read my early reply to you again. It's not the CPS, it's not a coil etc. ....you have a no crank problem when hot, confirm the cable condition first. a sure way to confirm the condition is do do a voltage drop check on the pos cable. Also a bad solenoid can create this problem
Since it's a hot crank issue we can rule out the trans range or Nuetral safty switch at this time.. Quote:
Originally Posted by gunther1000 did you read my post? Are you on drugs? | |
07-22-08, 02:43 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1999 Cadillac Catera | | Join Date: Mar 2008 Location: Ft Bliss, Texas Age: 37 | | | Re: Has all electrical but Won't start when hot Quote:
Originally Posted by gunther1000 did you read my post? Are you on drugs? | I think it's posts like these that make everyone ignore your posts. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
