Has all electrical but Won't start when hot - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Cadillac Catera and Cimarron Forum Discussion, Has all electrical but Won't start when hot in Past Cadillac Vehicle Discussion; As an update to when I had this issue, It was the battery terminals. The power wire to the starter/alternator ...
  1. #31
    gunther1000 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Mar 2008
    Nashville
    183
    Re: Has all electrical but Won't start when hot
    The power wire to the starter/alternator is long and can sometimes get corroded which causes enough power drop to give the impression there is full power but the starter will never engage.
    I solved this problem by wire brushing the terminals inside and out to all the positive and negitive connections.
    It sisnt look bad, infact it looked pretty clean but once a fresh layer was removed the car started fine for about a year.
    Sadly it has blown a head gasket and radiator now so it's sitting. But since a large paper weight isnt worth much I'm sure I will fix it and keep on steppin in this bear trap of a car.
  2. #32
    echo1sn@yahoo.com is offline Cadillac Owners Member
    Automobile(s): 2000 Catera
    Jan 2012
    37
    3
    yo good info i believe. So u changed the cable that runs in front of the engine right????? does this cable run the the left of the battery, and into a "hiding cover" then to where? is that hard to do? and hell yes my battery was hottttt when i tried to jump-start it one time.
  3. Remove Advertisements
