Replaced Rotors - Bad Brakes!
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Replaced Rotors - Bad Brakes! in Past Cadillac Vehicle Discussion; Hey guys! I just finished replacing my 2 front rotors. They were warped and made my steering wheel shake during ...
    frmg0014 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Catera Sport
    Oct 2007
    Toronto, Canada
    36
    99
    Hey guys! I just finished replacing my 2 front rotors. They were warped and made my steering wheel shake during braking. Upon installing the calipers/pads, I obviously had to purge some fluid out through the purge hole on the calipers in order to get them over the brake pads. Now that it's done, my brakes are too spongy! It needs to be pressed in more in order for the car to slow down. I'm guessing that I would need to bleed the system??? Can someone right me a guide on how to bleed the system... this will be the first time I'm doing this, and I don't wanna mess things up.
    CateraMV6's Avatar
    CateraMV6 is offline Cadillac Owners Connoisseur
    Automobile(s): Opel Omega
    Oct 2006
    Dearborn MI
    1,419
    Re: Replaced Rotors - Bad Brakes!
    Yeah the way you do that is with some sort of vise grips... or something that can squeeze the piston back in the caliper, you dont have to open the bleeder screw to do that... but since you have now you just got to fix it.
    I would recommend getting a buddy and have them sit in the car, then tell them to press on the brakes and hold, with as much pressure as they can, then you go out to the caliper and you open the bleeder screw, wait till all fluid comes out, at that point the pedal should be to the floor, close off the screw and tell your friend to let off, once fully released you tell them to press again, and you repeat until nothing but fluid comes out, I bet after the second or third try you will have all the air out of the system... also make sure you keep checking the level in the reservoir as that will go down drastically when you perform the operation.
    I dont think that you would have to do the rears since no air got in those lines... you should be fine with the above procedure....
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    I use a Mityvac. It's a hand held vacuum pump. Attach it to the bleeder nipple on the caliper, pump some vacuum and the fluid will be sucked down into a catch bottle along with any air bubbles. A gravity filler will prevent the mastercylinder reservoir from running dry. It's a one man operation except for your beer runner.
    http://www.drivewerks.com/tech/mult_bleed_brakes2.htm
    http://www.amazon.com/Mityvac-6820-B...2668812&sr=8-5
    http://www.mityvac.com/pages/products_bcbe.asp#MVA6832
    Elvin
