Radio, Door lock, and Fan
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Radio, Door lock, and Fan in Past Cadillac Vehicle Discussion; Driving home yesterday, Radio cut off, then I noticed the temp gauge getting really high, then when I parked and ...
    callingmonroe's Avatar
    callingmonroe is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS4 2010
    Mar 2008
    Richmond, Virginia
    57
    Driving home yesterday, Radio cut off, then I noticed the temp gauge getting really high, then when I parked and took the key out but door closed, I noticed the doors where still locked then all of a sudden the radio came on. Got out of the car and the fan started running and it seemed fine. Got up this AM started car, radio and all worked. Let warm up then radio cut off and then door lock did not move when in gear but worked with switch. Also temp started to climb and fan did not cut on. Anyone ever heard of this?
    Mar 2008
    Richmond, Virginia
    57
    Re: Radio, Door lock, and Fan
    Noticed something else, Everything works until I start the car once started it all stops. Radio goes off, fan I assume will not work and also door locks stop only when shifting gears. Now it seems to be in the ignition once started. Anyone know what to do?
    Yes, when I turn key to middle position everything seems to work, once started it all stops...
    Mar 2008
    Richmond, Virginia
    57
    Well no one checked in,
    but this is it! 10 amp fuse controlling the battery control module. This controls the coolant fan, radio, and doorlocks. When engine is on.
    Question is what caused it to blow???
