Help-Car filling up with water
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, Help-Car filling up with water in Past Cadillac Vehicle Discussion; Can someone please post a picture of the plug that needs to be removed to stop this from happening? Thanks ...
    Hoosier is offline Cadillac Owners Member
    Aug 2006
    40
    Thanks for your help!
    heavycat is offline Cadillac Owners Fanatic
    Automobile(s): Catera
    Mar 2006
    Toronto, Ont
    100
    Re: Help-Car filling up with water
    Where is the water acumulating?? I had a problem with water in the passenger front floor. I peeled back the carpet and found about 6 inchs in some parts, enough to submerge the air vents that run under the seats. I had to cut out alot of heavy soak foam to find the hole at a weld seam behind the glovebox. The drain plug in the engine compartment was clogged with leaves mud.
    To find this plug, open the hood, passenger side close to the windsheild remove the plastic panel closest to the mirror, you should see about 6 inchs of water built up in the cavity under the panel. Once the water gets up high enough it pours over a point that is not sealed. You may need a long needle nose to get the plug out, or use a strong shop vac. Hopefully this helps.
    Aug 2006
    40
    Yes, it's mainly in the front passenger side. Almost looks to be coming from behind the glove box. I'll take that panel off and try to get the leaves out.
    xanax06's Avatar
    xanax06 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Catera
    Jan 2008
    Philadelphia
    144
    I had the same problem, clearing the drain fixed it. You can get to it from underneath to pull any objects out.
  7. Remove Advertisements
