1997 Catera questions
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, 1997 Catera questions in Past Cadillac Vehicle Discussion; I was wondering it you could answers quick questions? 1)Anyone know of a site for 97 catera owners manuel or ...
    CaddyMD is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    1)Anyone know of a site for 97 catera owners manuel or can someone send me one.
    2)Headlights are fogged with moisture and is their anyway to take them out and clean them?
    3) Also sunroof isnt working the motor doesnt even make a sound. But it worked 2 years ago my parents said.Also my oil pressure,battery volage gauges don't work is this tied to the sunroof and the reason why they both don't work?
    ANY HELP IS GREATLY APPRECIATED?
    May 2008
    Re: 1997 Catera questions
    Actaually i found answers to 1,3 both fixed. (1997 Cadillac Catera)
    1) Headlights are fogged with moisture and is their anyway to take them out and clean them?
    2) My oil pressure gauge and battery voltage gauge dont work any reccomendations on how to fix them?
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Quote Originally Posted by CaddyMD View Post
    You sure the fogginess isn't on the exterior? Plastic headlights oxidize either from UV light, ozone, or pollution like acid rain. They are relatively easy to polish. The link takes you thread with a step by step demo. The results are genuine and amazing.
    http://archive.meguiarsonline.com/fo...ead.php?t=8011
    If the fogging is definitely internal I can only suggest drying it out somehow. I don't think you can separate the lens from the reflector without damage (I could be wrong). Remove the headlight housing and pull off the bulbs. Pour a little glass cleaner like Windex through the bulb holes and swish it around. Pour it out and rinse with distilled water. Use a blow dryer to shoot some hot air inside the housing until dry. Check the housing and bulb gaskets for leaks. I've never taken the headlight housing off my car so I don't know if there are any drain holes or vents but that moisture found its way inside somehow. Maybe during a rainy drive. This is what I would try. No guarantee it will work but it's surely cheaper than buying a new headlight assembly.
    Elvin
    May 2008
    bump Help!!!
    May 2008
    Quote Originally Posted by elvin315 View Post
    Elvin
    I tried cleaning my headlight lenses looked better but then fog came right back. Its definitly from the inside of the lense that has the condensation. Any help on taking lenses off the car and cleaning them and resealing them has anybody done this before any help?
    May 2008
    Nope the inside of the lense has condesation inside. Can i take apart the lense and clean it and then reseal it. Any help?
    drummer07 is offline Cadillac Owners Member
    Automobile(s): Catera
    Aug 2007
    24
    silica gel, or you can bake open the headlight in the oven and pry the lens apart. 220 for 10-12 mins
  10. Remove Advertisements
