valve cover gasket change
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, valve cover gasket change in Past Cadillac Vehicle Discussion; Does anyone have any information/pictures on how to change the valve cover gaskets. I am concerned taking off the top ...
    pghjoe is offline Cadillac Owners Member
    Automobile(s): 1997 Catera
    Apr 2008
    Pittsburgh
    34
    Does anyone have any information/pictures on how to change the valve cover gaskets. I am concerned taking off the top of the engine and am not sure of all the parts it requires. I believe that you need 4 gaskets, but what else should be changed (any o-rings or anything else)
    Should I just change the valve covers while am at it? Advanced auto parts sells the covers with gaskets for about $80 more per side.
    Thanks
    eastsidercaddy's Avatar
    eastsidercaddy is offline Cadillac Owners Fanatic
    Automobile(s): '97 Black Catera
    Jan 2008
    Jacksonville NC
    27
    210
    Re: valve cover gasket change
    Are you replacing the valve covers with gaskets, and want to know if you need o-rings?Right? Well I just put mine back on and yes, you need the o-rings that go on the inside of the valve covers. The valve cover gaskets seal up the covers, but when you screw it back down you need the o-rings that seal the top. Check under inside the cover and look where the holes are that the screws go in or when you take off the covers there will be small orings.
    dwheeler is offline Cadillac Owners Member
    Apr 2005
    Vacaville, CA
    38
    While you're at it, look up the thread about unclogging the PCV system. It seems to be the common cause for the valve gasket leaks.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Here are the guides courtesy of the Omega Owners Forum:
    Replacing the Cam Cover Gaskets
    Cleaning the Crankcase Breather
    Elvin
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    I just finished one of these and i took some pictures!!!!! I'll get the how-to up this week. It will be better for those of you with 1999-2001 cats, or anyone with the 3.2 or that have a later model motor transplanted into theirs? I'll quit rambling. Saves a lot of $ if you do it yourself though.
  8. Remove Advertisements
