Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: water leaking inside passage side?????
Old 05-11-08, 01:43 PM
Cadillac(s): 1997 Catera
View pghjoe's Photo Album
Casino Cash: $810
I have noticed some water (at least that is what I think it is) leaking into the cabin area on the front passenger side. It seems to be coming from behind the glove box area. Any ideas?
Thanks
  #2 (permalink)
Old 05-11-08, 06:41 PM
Army_MP_From_MO's Avatar
Cadillac(s): 1999 Cadillac Catera
View Army_MP_From_MO's Photo Album
Casino Cash: $5975
Re: water leaking inside passage side?????
Bad heater core
  #3 (permalink)
Old 05-12-08, 01:14 AM
Cadillac(s): 1998 Catera
View sirmqc's Photo Album
Casino Cash: $2775
I had this problem and it was a clogged drain tube. Their is a drain tube that goes from under the windshield on the passenger side to the front passenger wheel-well. In my case, and from other posts I've read on here, it gets clogged with leaves and junk. I tested this by running the hose on my windshield - I could see the compartment filling with water. It eventually fills up enough to flow in through the cabin air filter. If this is your problem, your cabin air filter is probably soaked.
  #4 (permalink)
Old 05-12-08, 01:11 PM
Cadillac(s): Cadillac
View cogsracing's Photo Album
Casino Cash: $995
I have the same problem with 97. The fluid on my floor is coolant, not just rain water. My situation is a bad heater core. You need to determine is it water or coolant.
  #5 (permalink)
Old 05-12-08, 02:09 PM
View cadillacroadside's Photo Album
Casino Cash: $2025
as posted the first thing you need to determine..is it water or coolant, coolant can only lead to a heater core issue, if its water then a leak test needs to be performed, many factors invlving water, body seam, hhvac seal, sunroof drain issue
  #6 (permalink)
Old 05-12-08, 03:16 PM
Casino Cash: $810
It is water, and when I look at the area around the cabin filter it is full of water. Could I just drill a hole in the basin? It doesn't look as if there is anything under it.
  #7 (permalink)
Old 05-12-08, 04:34 PM
Cadillac(s): '97 Forest Green Catera
View investor74's Photo Album
Casino Cash: $5954
The area that fills up is accessible by removing the cover to the cabin air filter. I cleaned out as many leaves from the bottom of the well as possible, then I applied the best tip I ever got on the Cadillac Catera Forum:
You tilt your wheels slightly to the left and you can see the rubber boot that covers the drain opening near the top of the right wheel opening. When I pulled the rubber boot off, I pulled the leaves out of the opening and water and debris came gushing out. That's all it takes - no additional holes necessary.
Barry
  #8 (permalink)
Old 05-12-08, 08:08 PM
Casino Cash: $5975
Don't drill, use a shop vac vacuum up the excess water, then use towels. You need to do it now, don't let it mildew up. Use a good carpet cleaner on it a couple of times and scrub it good.
  #9 (permalink)
Old 05-13-08, 03:06 PM
Casino Cash: $810
Barry...that was an awesome tip.
I pulled the plug and it gushed right out.
Thanks
  #10 (permalink)
Old 05-20-08, 07:50 PM
View david_gabriel15's Photo Album
Casino Cash: $300
i'm having this same problem as well. although i couldn't figure out what you were talking about when you said removing the boot(dumbfounded when comes to any mechanical work). is there anyway you could post a picture and have an arrow pointing to what you are talking about? if so i would be forever thankful.
thanks
  #11 (permalink)
Old 05-21-08, 12:21 PM
Casino Cash: $810
I'll try to get a picture, but i'm not sure how it will turn out.
If you turn your wheels all the way left and then look into the right wheel well, you'll see what looks like a flat rubber plug up high on the wheel well.
I pulled it with a pair of pliers and it released the water. Seems like it is working so far.
Joe
  #12 (permalink)
Old 05-22-08, 11:14 PM
Casino Cash: $810
Hopefully you can see the open whole where the plug was in the attached picture...
  #13 (permalink)
Old 05-22-08, 11:17 PM
Casino Cash: $810
I can't get it to attach. Give me your email and I'll send it to you.
Thanks
  #14 (permalink)
Old 05-23-08, 11:43 AM
View MaesMV6's Photo Album
Casino Cash: $3710
it depends if you uploaded it online and you have an address for it just do this: [IMG] url goes here without spaces [/IMG] and it will attach the picture for you. i use photobucket for all my picture uploads its free and easy
  #15 (permalink)
Old 05-25-08, 01:55 AM
Casino Cash: $300
my email is pearl.jam9@yahoo.com
i really appreciate you doing this
Tags: , , , ,
inside, leaking, passage, side, water
