cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: oil leak
Old 05-09-08, 08:25 PM
darksky47 darksky47 is offline
Cadillac(s): Cadillac
Casino Cash: $595
Angry oil leak
Ok here my trouble i have had a oil leak for about 6 months the sparks plugs holes were full of oil and the smoking was very bad so i replace the Cam Covers gaskets on both sides and drove it for three weeks thinking maybe that was old oil that has not burned off but it still smokes only from the right side i check the oil cooler it was dry i looked down the spark plugs holds they were dry so i replaced the Cam Covers again on the right side i even used oil dye trying to find the leak but i have no idea where it may be can anyone help me my wife is all over my a@& please help me befor i go crazy.
my email is darksky47@cainpro.com
  #2 (permalink)
Old 05-09-08, 09:46 PM
wildrage wildrage is offline
Cadillac(s): 2001 Catera Sport, 1993 Cadillac Eldorado Touring Coupe (N*)
Casino Cash: $1190
Re: oil leak
Same thing happened to me last month...changed cam covers twice. Make sure that your breather system is completely cleaned out. By that I mean the box is cleaned out, and the terminals where all the hoses going to the box go to are clean as well. Use carb cleaner on them.
In my case, I cleaned it out right, but the O-Rings on the breather box were shot and there was a vacuum leak that resulted. Pressure built up in the crank case and there was almost immediately smoke. My covers initially were smoking from the sides, but after I changed them the first time they leaked from the back, which confused me even more.
If you're sure the breather system is okay, check the oil filter and housing. There are not many points of failure for burning oil (as there is for coolant), so it shouldnt' be too hard to find.
  #3 (permalink)
Old 05-09-08, 11:27 PM
Casino Cash: $595
Re: oil leak
is the box your talking about on top of the motor that the four rubber tubes go to and the O-Rings where are they at is it only one on the bottem of that black thing on top of the motor.
  #4 (permalink)
Old 05-09-08, 11:29 PM
Casino Cash: $595
Re: oil leak
i for got if the o-ring is bad where can i get one and what do i ask for?
  #5 (permalink)
Old 05-09-08, 11:32 PM
Casino Cash: $595
Re: oil leak
if that o-ring is bad where do i get one and what do i ask for?
  #6 (permalink)
Old 05-09-08, 11:48 PM
Casino Cash: $1190
Re: oil leak
Yes, it's the box with the 4 tubes and a Cadillac symbol on it. Since you asked, I'm assuming you haven't cleaned it out. There are step by step instructions and pictures here:
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
The small tube on the passenger side of the breather goes into a little brass fitting not too far from the breather box. There is a little hole in the brass fitting - be sure it isn't restricted (you can use a small pin, but don't poke too far) The two larger tubes join and go into a much larger fitting near the rear of the engine. I had a harder time getting the larger one off, as there was a hose clamp on it and it was a real pain to loosen. The small tube on the drivers side appears to go into the EVAP system..and I didn't mess with it.
If you look at the breather box there are a total of 5 O-Rings. There are 2 connecting the main box to the smaller piece that goes into the throttle body, and 2 more that connect the smaller piece to the base of of the throttle body. There is also a larger one that connects the nipple on the bottom of the breather box to the hole on the top of the plenum. I didn't bother going to the dealer to get these Orings...I just went to an auto supply store and bought a huge set of Orings of all different sizes for around $15. You may wish to coat them with oil or lubricant before installing, as it can be a tight fit.
If your O-rings are shot, you should probably hear the vacuum leak, as it's right up on top of the engine. I couldnt hurt to replace them all, as they are very cheap and would probably take less than 1/2 hour. The breather system MUST be working perfectly, or you will blow oil out of your valve covers. As I said before, I started smoking again less than a day after I did my valve covers because the breather system was screwed up. Thankfully, after I got the breather system working the leak stopped...I didn't have to do the covers again.
  #7 (permalink)
Old 05-10-08, 09:02 AM
Casino Cash: $595
Re: oil leak
Ok i found the i found the box where the brass fiting with the little hold i dont have to take that hole thing off to clean it do i.
  #8 (permalink)
Old 05-10-08, 03:14 PM
Casino Cash: $1190
Re: oil leak
No. Just use a little carb cleaner on it. There should be a small hole in the middle...just make sure it's clear.
  #9 (permalink)
Old 05-11-08, 07:36 AM
Casino Cash: $595
Thumbs up Re: oil leak
Hey no more smoke i did just what you said im so happy i dont know how to thank you.
  #10 (permalink)
Old 05-11-08, 03:21 PM
Casino Cash: $1190
Re: oil leak
I'm just glad it worked. I was just as frustrated as you last month...I waited a week for the parts to come in, tore apart the engine (it was my first time, so I was a little nervous), replaced the gaskets, and still got smoke. I started second guessing myself and getting paranoid.
Now, if I had to do both the valve cover gaskets, I could probably do them in under an hour. At first doing things like removing the plenum and fuel rails seems really complicated, but after your first time, it's no problem.
The Catera is a little finicky, but thank god it isn't that hard to work on. It took me over 4 hours to do the valve gaskets on my Lincoln Mark VIII lol..
vB code is On
d3 cadillac event
cadillac v-series performance cts-v, sts-v, xlr-v
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac wood grain dash kit
cadillac unlock navigation
cadillac high performance exhuast
cadillac merchandise
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
