cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: car pulls when breaking
Old 05-06-08, 05:43 PM
MaesMV6 MaesMV6 is offline
Cadillac(s): Cadillac
Casino Cash: $2025
got my alignment done today which i was hoping would fix this problem but it still exsists. when i break for a light/sign, my car usually pulls right or left. just replaced the tie rod ends/alignment finished today which has fixed the car from pulling while driving, now its just when i brake.
the brakes are the original ones (opel). how do i tell if they are warped/need replacing. been putting off upgrading brakes but if they are bad then i'll go ahead and replace em now.
  #2 (permalink)
Old 05-06-08, 05:54 PM
cateraowner cateraowner is online now
Casino Cash: $4364
Re: car pulls when breaking
I'm getting the same problem (just change my tierods with an alignment too. )
Iam assuming that one caliper is gripping more than the other. I just got a set of GTO brakes so hopfully when I put that in it'll cure it.
sorry I'm don't know of a method to check if the calipers are working properly.
if the rotors are warped you will get steering wheel shake when stopping for high speeds
  #3 (permalink)
Old 05-06-08, 06:20 PM
TitanCTS TitanCTS is offline
TitanCTS's Avatar
Casino Cash: $525
Also check your front lower control arm bushings. If they are ripped they will allow the control to move in and out causing the car to pull to one side or the other.. Very common on our cars to fail.
  #4 (permalink)
Old 05-07-08, 08:13 PM
PEETYZ PEETYZ is offline
Cadillac Owners Enthusiast
PEETYZ's Avatar
Casino Cash: $1902
my friend had this problem and it was a part on the steering that connects right side and left side
  #5 (permalink)
Old 05-08-08, 12:52 AM
CateraMV6 CateraMV6 is offline
Cadillac(s): Opel Omega
CateraMV6's Avatar
Casino Cash: $4402
Idler arm bushing is shot... it allows the idler arm to move up and down and its only supposed to move left to right and when that happens it opens the toe on the front tires and that causes it to pull to either direction... replace it and you should be good... mine had the same issue... fixed it with new idler arm and new outer tie rod ends..
  #6 (permalink)
Old 05-08-08, 01:11 AM
Casino Cash: $2025
idler arm was replaced last summer when i got new tires. would it still be bad?
  #7 (permalink)
Old 05-08-08, 03:05 AM
Vinnyguti988 Vinnyguti988 is offline
Cadillac(s): 95' STS, Dads 93' Deville
Vinnyguti988's Avatar
Casino Cash: $575
have you tired to see if your discs are parallel..? if not they could be making your car pull to one side... but your safest bet would be to grease your calipers and check to see if you pull to a side again when braking...
  #8 (permalink)
Old 05-10-08, 10:47 PM
1998catera 1998catera is offline
Cadillac(s): 1998 Catera 1994 Eldorado 1995 Concours
Casino Cash: $550
I believe my issue was the tie rod end working itself loose.
vB code is On
d3 cadillac event
cadillac v-series performance cts-v, sts-v, xlr-v
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac wood grain dash kit
cadillac unlock navigation
cadillac high performance exhuast
cadillac merchandise
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
