Suspension problems
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Suspension problems in Past Cadillac Vehicle Discussion; I need some help here!! I have a 2000 Cat. When breaking, it feels like a bad rotor. Replaced rotors, ...
    billsyzfr-1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    8
    Suspension problems
    I need some help here!! I have a 2000 Cat. When breaking, it feels like a bad rotor. Replaced rotors, problem still there. Replacing struts soon. Front end joints, sway feel good, hoping it is just the struts. Need to know, do I have to replace the mounts as well? A while back I had a squeek when I turned at low speeds. Some bearing I was told. Is that bearing part of the strut mount? OK now for the 2nd part. The rear struts are leaking on 1 side, Going to replace them as well. Founr then at Advance for 70 for the air ride. Problem there is the rear tires wore down on the insides. REAL BAD ON 1 SIDE!! Is this an alignment issue in the rear? Appreciate any help!!
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Suspension problems
    Sounds like your car has had some rough miles. Need some more details.
    Quote Originally Posted by billsyzfr-1 View Post
    Explain. Why do you think it's the brakes? What exactly is the car doing? Does the car pull to one side? If it's pulling it could be bad lower control arm bushings.
    What front end joints? Do you mean the ball joints or the bushings? Sway whats? The swaybar bushings or the swaybar droplinks? If you're replacing the struts, why reuse old mounts. They'll just keep the car feeling sluggish.
    It could be the idler arm bushing, maybe.
    Monroe Max-Air Shocks, right? Are you replacing the air lines or reusing the originals? Crawl underneath and inspect them.
    That's usually caused by too much negative camber. It could also be worn or broken trailing/control arm bushings. There are adjustable bushings that help solve that problem. Check the spring mounts. They get crushed over time and change the alignment. The springs themselves sometimes crack too.
    Read my posts on suspension upgrades. Since your practically rebuilding the front and rear suspensions you might want better than the stock components.
    http://www.cadillacforums.com/forums...n-issue-3.html
    Elvin
    vanclot is offline Cadillac Owners Member
    Jun 2008
    11
    Sunds like it may be the stabalizer link. try moving it up and down to see if their is any play. i currently had a similar problem as you and turned out to be the stabalizer link
