cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: MAF Sensors Purpose
Old 05-01-08, 04:46 AM
Leon3 Leon3 is offline
Cadillac(s): Cadillac
Casino Cash: $1090
Question MAF Sensors Purpose
What exactly is the function of the MAF sensor ? Does it wire straight to the the computer or does it send signals to another car conponent ? Lastly how would its malfunction cause a miss on 246 ? Just curious but serious.
Thanks in advance
  #2 (permalink)
Old 05-01-08, 09:49 AM
wildrage wildrage is offline
Cadillac(s): 2001 Catera Sport, 1993 Cadillac Eldorado Touring Coupe (N*)
Casino Cash: $1360
Re: MAF Sensors Purpose
The Mass Airflow Sensor meters the air coming into the engine in order to determine the fuel/air ratio. When they go bad or are dirty they generally cause rough idling, sluggish acceleration, or missfiring on all or random cylinders. If you are consistantly getting a miss on a particular cylinder you should look more towards the plug or coil/wire (depending on your year).
  #3 (permalink)
Old 05-02-08, 11:05 PM
Cadi Cat Cadi Cat is offline
Cadillac(s): 2000 Catera
Casino Cash: $3642
I have a question. What's the difference between the Mass Air-Flow Sensor vs the Mass Air Sensor?
  #4 (permalink)
Old 05-03-08, 04:39 AM
Warez Warez is offline
Casino Cash: $1356
Same thing.
  #5 (permalink)
Old 05-03-08, 06:52 AM
ewill3rd ewill3rd is offline
Cadillac Technician
Cadillac(s): none
ewill3rd's Avatar
Casino Cash: $6322
The MAF or "Mass Air Flow" sensor measures the actual volume of air entering the engine for combustion.
Basically a sense wire is placed in the flow of air and using one of a couple methods a small processor calculates the airflow and sends a signal back to the engine controller. The ECM then uses other sensors to calculate the required amount of fuel needed for the conditions being measured by things like the MAP (intake pressure) sensor, engine coolant temperature, calculated load, current gear selection, throttle position, etc...
What happens typically on Catera is that when the MAF fails it will give false readings.
If the MAF is lying to the ECM the ECM will think it is getting more or less air than it actually is, this causes an imbalance in the air/fuel ratio and the engine runs lean or rich. Sometimes this will have more of an effect on one bank or the other with that engine.
I have seen big issues with failing MAF sensors on Catera that cause all sorts of misfires and drivability problems.
Some manufacturers have slightly different names for sensors but GM has always called it a MAF sensor.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #6 (permalink)
Old 05-03-08, 10:08 AM
Army_MP_From_MO Army_MP_From_MO is offline
Cadillac(s): 1999 Cadillac Catera
Army_MP_From_MO's Avatar
Casino Cash: $2220
I love it when a Cadillac Technician visits our threads.
  #7 (permalink)
Old 05-16-08, 01:33 PM
pghjoe pghjoe is offline
Cadillac(s): 1997 Catera
Casino Cash: $740
How difficult is this part to change on your own???
  #8 (permalink)
Old 05-16-08, 03:03 PM
Cadillac Technician
Cadillac(s): none
ewill3rd's Avatar
Casino Cash: $6322
Most MAF sensors are fairly easy to replace.
Some just have two hose clamps holding them in place in the air stream, some are 2 or three screws holding them on an assembly.
Some older ones are built into the airbox (and some new ones too).
Catera has one that is fairly easy to access, it is over to the right side of the car in the ductwork.
Pretty easy to replace once you get some of the ductwork out of the way.
  #9 (permalink)
Old 05-16-08, 06:44 PM
Casino Cash: $740
How would someone get information on how to change this and other parts of the car?
  #10 (permalink)
Old 05-16-08, 08:42 PM
Cadillac Technician
Cadillac(s): none
ewill3rd's Avatar
Casino Cash: $6322
A factory service manual "FSM" is a good place to start, although sometimes it is easier to figure it out yourself than it is to look it up in the manual.
I think there might be some information scattered about the forums, using the "search" function might get you some good results.
The FAQ often has a lot of good info in it although not sure about Catera stuff.
If all else fails just start a post and ask.
If you get the part and look at it and then look at your car to find it you should be able to see how it is installed and pretty much see how you can change it out.
If you still have problems most independent shops would be willing to toss parts on for a few bucks but don't look to them to guarantee that it will fix the problem.
Tags: , ,
vB code is On
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
