Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: MAF Sensors Purpose
  1. #16
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: MAF Sensors Purpose
    Sometimes they change the design slightly, maybe the air duct is a different size, maybe the connector is different. I don't specifically know but part numbers can change from year to year.
    Usually the smaller run parts (fewer production models) cost more.
  2. #17
    wildrage is offline Cadillac Owners Member
    Automobile(s): 2001 Catera Sport, 1993 Cadillac Eldorado Touring Coupe (N*)
    Dec 2006
    Bridgewater, NJ
    35
    92
    gmpartsdirect.com has one for $297.00...thats about as cheap as you can get it. you may also want to try to clean it off with some rubbing alcohol..they can sometimes get dirty...just be sure not to apply to much pressure to the probes. The MAF is ricidiulously easy to remove, so it may be worth it to try cleaning it...if not, you'll have to shell out the $$$.
  3. #18
    rruff98 is offline Cadillac Owners Member
    Automobile(s): catera
    Oct 2012
    47
    11
    just a question..what is the sensor in between the airbox filter and the maf sensor? is that another type of sensor for air? from 98 catera
  • You may not post replies
