cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Catera '99: Trunk lid not closing and Bose radio problems
Old 04-29-08, 08:23 PM
mikescat1 mikescat1 is offline
Cadillac(s): Cadillac
Casino Cash: $360
After some repairs were completed on my Catera '99 a series of problems started. The repairs done were to replace the rotors, correct oil leaks/replace gaskets, change spark plugs, fuel filter and front end alignment.
Immediately after the above listed repairs, the Bose radio and trunk release work erratically. Sometimes no radio at all and trunk release would not work either from the dashboard or the remote. Now the trunk would not even close!
I got a newer remote and had the dealer reprogram it, but the trunk and radio problems remain.
After the rotor replacement, I noticed some rattling noise seemingly coming from my front wheel, for which the mechanic checked and said it needed anti-rattling clips (dealer item). Funny enough, just after putting the wheels back on, the radio worked for a couple hours before it stopped again!
However while the mech was showing me where the clips would go, I noticed that there was a small wire (one for each front wheel) with sort-of a clip head (like sensor) that was not not connected. He told me they were sensors to detect brake wear and I could only connect them with a new special brakes and replacement of the sensor/wire. I'm wondering whether this sensor/wire may be responsible for my radio/trunk woes?
I have read on this forum that the radio and/or trunk problem could be due to the malfunction module, week battery, and maybe a few other possibilities.
Recently, the radio came at start, but cutoff immediately the engine fan came on. Making me to wonder if the radio/trunk woes are due mainly to the multifunction modules as others have hinted.
The battery voltage read lies about halfway the dashboard meter (please attached image).
Also, the fuel door has stopped working properly a while ago, but the door is open so I can refuel.
I would appreciate suggestions on how to properly troubleshoot and solve this problem. Thanks in advance.
  #2 (permalink)
Old 05-08-08, 11:14 PM
5littlebit 5littlebit is offline
Casino Cash: $325
Re: Catera '99: Trunk lid not closing and Bose radio problems
try putting your cat in reverse then pressing the release for the trunk or fuel ( be sure to keep your foot on the brake) it works for me. I will replace the module when the part comes in and hope that fixes the remote and radio.
  #3 (permalink)
Old 05-10-08, 08:17 PM
Casino Cash: $360
Thanks for the suggestion. I replaced the multifunction module and now the radio and trunk work. I noticed also that one of the bolts on the trunk latch was missing. Hence, I replaced the hex-screw and now the trunk closes without problems. However, the fuel door is still not auto controlled, but I'm not sweating that.
Only other problem with the Catera is recurrent oil leaks despite it being fixed. Just noticed smoke from under the car one day. Mechanic said an O-ring was broken. Ring replaced but still small oil leaks!
  #4 (permalink)
Old 05-10-08, 10:48 PM
cateraowner cateraowner is offline
Casino Cash: $4364
just wondering...
my trunk doesn't close unless I lock the car. is this a modual thing?
Tags: , , , , , ,
vB code is On
d3 cadillac event
cadillac v-series performance cts-v, sts-v, xlr-v
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac wood grain dash kit
cadillac unlock navigation
cadillac high performance exhuast
cadillac merchandise
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
