Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Coolant leak could it be head gasket or hcv?
Old 04-11-08, 03:06 PM
PEETYZ's Avatar
Cadillac Owners Enthusiast
View PEETYZ's Photo Album
Casino Cash: $1902
Ok heres the symptoms the car (98 catera) will lose coolant and usually not show any signs of smoke at all. The engine runs perfectly fine no codes either. There is no signs of coolant and oil mixing either thankfully My friends dad thinks its a head gasket but i think its not because the car runs great and no codes it just looses coolant and we cant find where as u cant see any drips from car. I told him the computer would throw a cel pretty fast im afraid not to mention 02 sensors so im puzzled they are going to take the car to my old mechanic who worked on the catera when i owned it but do you guys have any ideas? Im sure they will pressure test the system.
  #2 (permalink)
Old 04-11-08, 09:04 PM
todd2fst4u's Avatar
Cadillac(s): 1998 Catera
View todd2fst4u's Photo Album
Casino Cash: $6159
Re: Coolant leak could it be head gasket or hcv?
Could be the HCV. it doesn't leak steadily when it does leak, only intermittently which could be the reason you can't find any signs of it.
sounds like you got rid of the car at a good time based on all the posts you've been making.
  #3 (permalink)
Old 04-12-08, 09:26 PM
Cadillac(s): Cadillac
View livebait's Photo Album
Casino Cash: $395
When checking into a leak that is located on the driver side on the Catera there is usually a few things to look for.
Is the leak dripping from the manifold? If it is, then it will probably end up being the Head Gasket.
But before assuming the worst check out the obvious first.
Look for a leak in the HCV, Coolant Return Pipe, Oil Cooler Cover, Water Crossover or even the thermostat.
I just completed a complete head job on my Catera and it was the head gasket that caused the mystery leak coming from the Driver Manifold.
One thing that should be noted, The factory engine coolant is the red type and that type is highly corrosive. When changing over the head gasket or doing a complete Flush then change to the Green coolant. I can show the damage on my head gaskets that where eaten away because of the coolant. The head was not damaged but you could clearly see where the coolant ate into the gasket and eventually worked its way out into a leak.
I will post some picture if you would like just email me
Thanks Keith
  #4 (permalink)
Old 04-13-08, 12:17 AM
View cateraowner's Photo Album
Casino Cash: $6614
Thanks Keith
is it ok to switch coolant like that?
I assume the dexcool is the redstuff, and the green stuff is the regular coolant right? I've always had problems with the dexcool crap, so if I can I will flush it out and put regular coolant in.
I'm having the same mystery coolant leak and and see anything. I only notice the tank get lower, but no wet spots. ( i smell it when I drive the car hard.)
it would be awsome if you can post a picture where you found you leak.
Thanks
  #5 (permalink)
Old 04-13-08, 12:42 AM
PEETYZ's Avatar
Casino Cash: $1902
catera owner same symptoms here tank lowers not leak or drips seen
  #6 (permalink)
Old 04-13-08, 11:55 AM
View Motohead1115's Photo Album
Casino Cash: $410
Thanks
Same thing here (I smell it to) in addition I've noticed some milky sludge around the edge of the oil filler cap.I changed the oil but it looks ok no smoke out the tailpipe either no coolent in oil says Headgasket ok but skudge in oil filler tube says Headgasket blown anyone ever tryed this? http://www.steelseal.com/eng/home.html
  #7 (permalink)
Old 04-13-08, 02:13 PM
Army_MP_From_MO's Avatar
Cadillac(s): 1999 Cadillac Catera
View Army_MP_From_MO's Photo Album
Casino Cash: $5975
My only thought is if it finds and seals a blown head gasket, what keeps it from finding and filling a vital engine part?
  #8 (permalink)
Old 04-13-08, 09:52 PM
Casino Cash: $395
I just finished rebuilding another cat engine today. The only thing wrong with these things is the accessories. Once you got them out of the way the rest is pretty basic. Another head gasket chewed by the antifreeze.
I have checked with the cadillac service and the green type coolant is warrantied. The rad shop said that they would never put the red into anything. The only thing i would suggest is to make sure the car is completely flushed out before changing.
The white stuff in the filler tube is not a sure sign of a bad head gasket. If your car is not being driven for long periods of time then a moisture of that will build in the filler tube. I have pulled off the Valve cover gaskets thinking the same thing but it is only in the filler tube.
I found that a good run on the car will even make that moisture go away. The cause of the moisture is from the engine crankcase not ventilating properly. When this happens you will have the tendancy to blow the valve cover gaskets. Take the time to maintane the breather system. It is a lot cheaper then what could happen. There is a great how to in the opel area.
Respectfully Keith
www.livebaitandtackle.com
  #9 (permalink)
Old 04-14-08, 01:30 PM
Cadillac(s): 92' Eldorado, 97 Catera
View Po Pimp's Photo Album
Casino Cash: $2782
It is not the red coolant. It is when people mix the green and the red together. Then it becomes corrosive.
Sludge on the oil filler cap could be from a number of things. The most common is the use of convention oil and not synthetic.
You guys are really just going to have to inspect the backside of the engine. It is blistering hot back there during operation, add on the fact that the exhaust runs directly under a couple components and odds of you seeing any on the ground is greatly dimenished. This is something you would rather do sooner then later. You can cause further damage to ignition coils....etc..from letting it go.
  #10 (permalink)
Old 04-16-08, 10:52 PM
PEETYZ's Avatar
Casino Cash: $1902
I called it............ my mechanic called my buddy and said heater control valve my friend was relieved fearing for the worse of a blown head gasket
  #11 (permalink)
Old 04-17-08, 12:12 AM
Casino Cash: $6614
good to hear.... any one know how I check that? I don't know where or what the heater control valve is...
  #12 (permalink)
Old 04-18-08, 01:35 AM
PEETYZ's Avatar
Casino Cash: $1902
its the thing behind engine with hoses going into it and out of it it has vacume line on top
Tags: , , , , ,
coolant, gasket, hcv, head, leak
