cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: weird steering problem
Old 04-10-08, 09:44 PM
PEETYZ PEETYZ is offline
Cadillac Owners Enthusiast
PEETYZ's Avatar
Casino Cash: $1902
Hey im havin a strange problem with my buddys catera does this car have a steering rack? the steering is tight but when u hit the brakes the car pulls left and wheel turns its not a sticky caliper they were replaced and problem still stands
  #2 (permalink)
Old 04-10-08, 10:34 PM
PEETYZ's Avatar
Casino Cash: $1902
Re: weird steering problem
im afraid it may be the steering box =( anyone know of any forsale?
  #3 (permalink)
Old 04-10-08, 10:46 PM
Cadi Cat Cadi Cat is offline
Cadillac(s): 2000 Catera
Casino Cash: $3642
It does this on a straight flat road?
  #4 (permalink)
Old 04-11-08, 12:25 AM
PEETYZ's Avatar
Casino Cash: $1902
well its weird if you jerk the wheel it will sit in a off center direction either way u jerk it and will pull to the left during braking when wheel is in center it brakes fine im confused
  #5 (permalink)
Old 04-11-08, 03:01 AM
elvin315 elvin315 is offline
Cadillac(s): Platinum 2001 Cadillac Catera Sport
elvin315's Avatar
Casino Cash: $8181
No rack & pinion steering. The Catera uses reciprocating ball. The power steering is variable effort, where the power assist is strongest as low speeds and decreases as you go faster. Could be that the steering pump might be low on fluid or need a flush. Check the hoses for leaks. Might need a new pump. Not sure if the ECM had to do with steering but you never know. Any codes?
Might not be the steering at all. Worn or damaged front end control arm bushings could be causing the wheels to toe out under braking. Not sure how to check them but I know it involves using a pry bar to force the control arm away from its mount and look for tears in the rubber or hydraulic fluid (the rear/vertical bearing is filled with oil). Could be worn tie rod ends.
Elvin
  #6 (permalink)
Old 04-11-08, 01:53 PM
PEETYZ's Avatar
Casino Cash: $1902
by the way discount steering has steering boxes for all year catera for 350 with a year warranty cheapest place other wise is gmparts direct 1,200 no warranty
Is steering box a common thing to go out at 115k or so?
  #7 (permalink)
Old 04-11-08, 01:58 PM
PEETYZ's Avatar
Casino Cash: $1902
by the way the car is aligned and the shop said u may have a bad engine mount? no engine codes either
Tags: , ,
vB code is On
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
