Suspension Issue
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Cadillac Catera and Cimarron Forum Discussion, Suspension Issue in Past Cadillac Vehicle Discussion; Ever since my Mom had this car, when hitting a speed bump, even at low speed, there was a clunk ...
    wufibug is offline Cadillac Owners Member
    Aug 2004
    San Diego
    20
    Suspension Issue
    Ever since my Mom had this car, when hitting a speed bump, even at low speed, there was a clunk from the right side suspension. Asked the dealer who said that all Catera's had a clunk. Not satisfactory. It has gotten somewhat worse. I put drilled slotted rotors on last summer. After a short while, after the brakes warmed up, I experienced severe buffetting through the steering wheel and I could see the gear shifter shake. Concluded it was badly warped rotors and exchanged them [the wheels had been overtightened, and I was careful to torque on the second set]. Cured for a short time. Comes back after any hard braking. I am still leaning to bad rotors [2 sets!!??], but with the clunk, I am wondering if this might be related to the suspension issue. I have looked underneath, but did not see anything obvious. Wierd, I know, but any ideas? Oh, one other issue. This has the chromed wheels. I had a flat on the left front, and when the tire was off I noticed some corrosion at the bead. That wheel/tire has a slow leak at the bead. I am wondering if the overtightening may have warped a wheel, not the rotors. I thought these wheels were chromed steel, so warping was not much of an issue. Wrong?
    Army_MP_From_MO's Avatar
    Army_MP_From_MO is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac
    Mar 2008
    El Paso, Texas, United States
    45
    240
    Re: Suspension Issue
    I've got the same problem with the clunk noise coming from the passenger side front when going over a speed bump. I never hear it any other time, of course, I'm pretty anal when it comes to missing potholes. I haven't tried tackling this yet. Keep me informed if you find anything out. Thanks
    PEETYZ's Avatar
    PEETYZ is offline Cadillac Owners Enthusiast
    May 2006
    Ohio
    535
    loose steering ? i replaced my idler arm and srtuts and the problem almost completely went away
    sccatera97 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Cadillac Catera 2002 SEville STS
    Jan 2008
    107
    Check yor end links on the front sway bar. The wear out and if the car is off the ground, it is hard to check. You can get them from Advance auto parts for about $26 each. Here is a photo of what the end link looks like.
    Mar 2008
    45
    240
    You guys are a wealth of knowledge. I think joining this forum was the best thing I could have done!
    Jen_Kenne's Avatar
    Jen_Kenne is offline Cadillac Owners Member
    Automobile(s): 1999 Catera
    Feb 2008
    South Florida
    24
    Quote Originally Posted by Army_MP_From_MO View Post
    Sure beats the dealer!
    Jan 2008
    107
    I have two 97 Cateras, 1 I drive and 1 I am dismantling. I am using it for my test mule for my SC V6 conversion and if I need to figure out how something workd, I try it on the mule so I don't tear up my driver. If I can help, I am glad to.
    Aug 2004
    San Diego
    20
    No, the steering seems OK. It really sounds like a strut mount to me. Car has under 70k, so the struts and mounts should be OK, but . . . . If I figure this one out, I'll post. Thanks for the suggestions.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    The front suspension has several known issues. The clunking is usually attributed to the anti-sway bar down links or the steering tie rod ends. Even if the steering seems fine don't rule them out.
    Elvin
    cateraowner is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Oct 2007
    260
    please keep us posted.
    I'm hearing clunking, but the weird thing is the colder it is the more clunking I hear. on warm days I rarely hear it.
    gunther1000 is offline Cadillac Owners Fanatic
    Mar 2008
    Nashville
    183
    I'm hearing a small clunk also but do need front sstruts so I think it may be them bottomong or topping out at the end of the stroke hitting the bumpers when going over sharp bumps... I have a small shake also that is very similar to the above withthe trans shifter and head rest moving slightly like a wheel balance issue but we will see...
    MaesMV6 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS
    Feb 2008
    Las Vegas
    31
    i got the same problem. already replaced the idler arm, and the outer tie rod ends. got new tires put on less then a year ago, got it balanced and aligned then, ball joints seemed fine. gonna go ahead and replace the anti sway bar links friday. anything special i gotta do? just jack up the car pull the old ones off and put on the new ones?
    Jan 2008
    107
    No they are relatively easy to install. You will need a wrench to keep the end from spinning. I think it is a 17 mm. When you look at the link where it connects, you will see flat spots to keep it from spinning when you take the nut off.
  16. #14
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 DTS,2007 STS V8
    Dec 2006
    New Jersey
    44
    601
    A pretty common issue on front ends on these were lower control arm bushings. You can check them with a pry bar. I've done several. HTH.
  17. #15
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Quote Originally Posted by cadmanchris View Post
    Yes, but they'll cause tires to wear on the inside, alignment problems, and tramlining but not clunks.
    Elvin
  18. Remove Advertisements
