cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Mystery Coolant Leak
  #11 (permalink)
Old 04-08-08, 07:08 AM
livebait livebait is offline
Cadillac(s): Cadillac
Casino Cash: $360
Re: Mystery Coolant Leak
Well i just want to update everyone about these leaks,
The problem is a mystery leak that appears from the driver's side rear engine area, the manifold area. Well if you have read all the above you will see a good guidline to follow.
First look at the Heat Control Valve, the Water Coolant return pipe, the Water crossover, the oil heat exchanger cover, Thermostat or any other possible spot.
Is there still a leak, well you can almost guarantee its the Head Gasket. Does it still leak there when the coolant is drained. Then it is the head gasket.
We here have found that it does not take that much longer to change the head gasket if you have gone as far as removing the water return pipe from the back of the engine.
Remember it is still not an easy job but really not to complicated as long as you have room to put all your parts that you need to remove in order. One step at a time.
I have developed a complete step by step guide to removal of the head gasket and how to discover that mystery leak on the way in. You should be prepared to change the head gasket if it is the fault when starting this guide. You may be surprised how simple the repair is and if you look around you will be able to get the required parts at a reasonable price.
If you need assistance or would like my guide i can send it to you just ask
Tags: , , , ,
vB code is On
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
