| Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron. | Cadillac Forums: LED Bulb Conversion  | |
04-02-08, 01:15 AM
| | Cadillac Owners Member | | Join Date: Nov 2005
Casino Cash: $450
| | | Re: LED Bulb Conversion Thanks for the pictures! They look like they match the high mount stop bar nicely. I am all bout making it look as close to a factory job as possible. I had thought about looking into having some LED pannels made for the brake/tail lights (like the turn signals) - but have no idea where to look, how much $$, who to go to, or if it is even possible. |
04-02-08, 07:34 PM
| | Cadillac Owners Fanatic Cadillac(s): 2000 Catera | | Join Date: May 2005 Location: Michigan Age: 23
Casino Cash: $3297
| | | Re: LED Bulb Conversion Quote:
Originally Posted by Army_MP_From_MO which brand side markers did you pick up? | I forget but they have them at autozone. That's where I picked them up at. They have Red and Amber |
04-02-08, 07:37 PM
Casino Cash: $3297
Originally Posted by kmcatera00 Thanks for the pictures! They look like they match the high mount stop bar nicely. I am all bout making it look as close to a factory job as possible. I had thought about looking into having some LED pannels made for the brake/tail lights (like the turn signals) - but have no idea where to look, how much $$, who to go to, or if it is even possible. | Yeah, I've been looking for those panels too. I've come up with nothing. |
04-03-08, 03:16 PM
| | Cadillac Owners Member Cadillac(s): '97 Black Catera | | Join Date: Jan 2008 Location: Leesburg GA Age: 18
Casino Cash: $1580
| | | Re: LED Bulb Conversion I LOVE the LED conversion, especially since I changed the look of my rear tail lights a bit. I love hi-tech stuff that's cheap especially the LED. I got my LED Bulbs off of a chineses manufacturer that sells them at a decent price for ultra white 30 some odd LED bubls. I got 2 for around 32 dollars on eBay. Here's a pic of them just on RUNNING LIGHTS. It looks like brake lights.
also, depending on the number of LED's your red housing may look a little pinkinsh like mine since the LED's are around 1.5 times brighter on running mode. AND INSANELY bright when braking around 2 times brighter than filament. NEVER get the RED LED's they sell at autozone or advance auto. These are actually darker if you put them in your RED brake housing. RED+RED = DARK RED. ALWAYS get the ultra brite WHITE LEDS  |
04-03-08, 08:19 PM
| | Cadillac Owners Enthusiast Cadillac(s): Platinum 2001 Cadillac Catera Sport | | Join Date: Jan 2007 Location: Buffalo, NY Age: 54
Casino Cash: $5656
| | | Re: LED Bulb Conversion Personally, I'll stay with incandescents. Those LEDs look too bright. I know I hate following a car that has a cracked tail light lens or the brake light switch shorted. Why do I want to antagonize the drivers behind me or attract unnecessary attention from the police?
Elvin |
04-04-08, 02:14 PM
| | Cadillac Owners Fanatic Cadillac(s): 1997 Catera | | Join Date: Apr 2006 Location: Nashville TN
Casino Cash: $1322
| | | Re: LED Bulb Conversion well...you asked...the answer? cause police and other drivers are antagonized when a light doesn't work, and the incandescents fail on a regular basis. The LED will probably last the life of the car. And you don't HAVE to get the ultrabrights, you can get those that are just a bit brighter than incandescents. They also last the life of the car. If you do match the housing color, then a cracked lens wouldn't be an issue either.
My $0.02.
(maybe I should get back to work....) |
04-18-08, 10:51 PM
Casino Cash: $3297
Originally Posted by kmcatera00 Thanks for the pictures! They look like they match the high mount stop bar nicely. I am all bout making it look as close to a factory job as possible. I had thought about looking into having some LED pannels made for the brake/tail lights (like the turn signals) - but have no idea where to look, how much $$, who to go to, or if it is even possible. | Here, I found something you might be interested in. But you would have to tear apart the housing and glue them in or something. Nothing I want to do but the cord simply plugs into the factory socket so at least you won't have to rewire anything. http://cgi.ebay.com/ebaymotors/1-RED...6473QQtcZphoto |
04-21-08, 12:26 PM
Casino Cash: $1322
| | | Re: LED Bulb Conversion Ok, I decided to try some LED bulbs for my brake / parking lights and my turn signals this weekend. On 97 Catera, it has this one plastic bulb mount for both bulbs in each lens. There is total of 4 wires running to the bulb mount: park, brake, turn, ground. This is what I found:
Brake / Park are the correct polarity in the socket. Plug and play (I think). More later on that.
Turn is OPPOSITE polarity in the socket. The common of the brake / park bulb (the shell) goes to the single pole of the turn bulb.
Since this is a solid piece of metal, the only way I see to properly reverse polarity is to cut the metal and solder the correct connections (simply swapping wires cannot work as the shell of one bulb and the center post of another bulb are using the same piece of metal??)
My third brake LED is not working. However I did not notice if it was working before I started. I did swap back to the original bulbs to eliminate the possibility that the LED bulb was causing a problem.
I have more investigation to do. SInce I didn't see anyone mention this, then...that is what i see, and if anyone else noted this problem with the socket polarity - can you enlighten me on how you corrected it? (97 thru 99 I assume, I didn't note any 2000 and newer having any issue). |
04-21-08, 07:47 PM
| | Cadillac Owners Member Cadillac(s): 1999 Cadillac Catera | | Join Date: Mar 2008 Location: Ft Bliss, Texas Age: 36
Casino Cash: $1710
| | | Re: LED Bulb Conversion I got the same problems when I took advice to rewire the socket. That won't work. I've got a pair of resistors on the way that I've been informed will fix the problem. I'll keep ya updated. Wish me luck! |
04-23-08, 11:23 PM
Casino Cash: $3297
| | | Re: LED Bulb Conversion In case anyone plans on putting leds in the instrument panel. Don't waste your time or money. they don't work. I'm guessing because of the dimmer switch. I couldn't get them to light. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
