2000 catera turn signal flasher issue
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, 2000 catera turn signal flasher issue in Past Cadillac Vehicle Discussion; My 2000 catera has a problem with the turn signal flashing that whenever I turn the right or left turn ...
    Just_me is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    10
    My 2000 catera has a problem with the turn signal flashing that whenever I turn the right or left turn signal it flashes really fast and then slow (changing all the time). I cheacked and all my light bulbs are working great. I'm thinking it might be the "turn signal flasher relay" but i'm not sure. Does anyone know where to get really cheap ones if that's the case? Thanks!
    CateraMV6's Avatar
    CateraMV6 is offline Cadillac Owners Connoisseur
    Automobile(s): Opel Omega
    Oct 2006
    Dearborn MI
    1,419
    Re: 2000 catera turn signal flasher issue
    Check autozone for one, they should be standard GM relays, I had a similar issue and mine turned out to be the connection on the bulb was not good, so when it was gold it didnt work but when you tap the lens or the weather warmes up it would work... so I just tightened the terminals and fixed my issues...
    When it flashes real fast see which bulbs are flashing, the one that isnt is the problem... now do your turn signals light up when you turn the parking lights on... if they do you have a blown bulb for sure...
    miaboone is offline Cadillac Owners Member
    Automobile(s): Catera
    May 2012
    1
    In my 2000 catera, I recently changed my battery and my speedo, psi doesn't work. My brake, air bag and TC lights are on. Also my radio won't work and my signal lights plus the position stick itself won't click. OMG, WTW!!! (Please help someone.)
    matrixebiz is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Mar 2012
    47
    33
    Just wonderng if anyone had this fixed? I changed the flasher relay and the bulbs are fine but still speratically flashes fast when it's cold outside.
    Any ideas?
    kaustein is offline Cadillac Owners Enthusiast
    Jul 2008
    712
    As I and others have stated before, the car is an electrical nightmare. Seat memory, worked and sometimes tried to fold me in half.
  8. Remove Advertisements
