| Re: Headlight Assembly Removal on 1999 Catera Alright, thanks guys. The reason i was removing the headlight originally was to replace the hi-beam bulb that wasn't working on my car. It's a tight fit between the battery and the headlight so in my car i just simply remove the assembly, but it's 10x's easier,.... I went ahead and just replaced the bulb, and now that my hand's all torn up it still doesn't work!!!!!! I'm going to take the headlight out to look at the wiring. Also, the assembly inside shakes around. Would that be a broken bracket piece inside or something? Thanks Again, Luke.
