aftermarket stereo install for 00-01 Catera - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Cadillac Catera and Cimarron Forum Discussion, aftermarket stereo install for 00-01 Catera in Past Cadillac Vehicle Discussion; Yeah that BassLink looks nice. With that module thats supposed to be released with it soon, hooking those 6.5s in ...
  1. #16
    Matera97's Avatar
    Matera97 is offline Cadillac Owners Fanatic
    Automobile(s): '97 Catera (Ocean)
    Mar 2009
    Halifax
    31
    463
    Re: aftermarket stereo install for 00-01 Catera
    Yeah that BassLink looks nice. With that module thats supposed to be released with it soon, hooking those 6.5s in the rear shelf would be a breeze, just run the wires, hide them, cut out the fiber glass, mount the speakers and you're in Bass Heaven
  2. #17
    matrixebiz is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Mar 2012
    47
    33
    Hello, is there another guide like this? The pictures are not showing up anymore
    Quote Originally Posted by catera00 View Post
    Ok, since there is nothing on the forum about how to install an aftermarket stereo in a 2000-2001 catera, I'm gonna share my experience. Unless theres a magical kit that fits perfect, you'll have to modify it to make it work. The install kit I bought was by Best Kits. It says its for a 96-01 Catera/ Deville/Grand Prix. This is the brand a lot of installers sell. I bought it from a professional shop.
    As with everything else on this car, it did not install easily. I had to modify the pocket to fit in the opening. The pocket was 1/2 inch too wide. I had to cut 1/4 inch from each side of the pocket all the way up to the shorter of the 2 mounting "legs". Do not cut all the way to the front opening of the pocket! Stop about 1 inch away. I also had to trim a couple other spots on the kit to get it to fit.
    I removed the mounting bracket from the car to make it easier to measure everything. You can see here how much wider the pocket is than the opening it needs to go into.
    Here's the kit after I cut the sides enough to fit. Theres also a whole cut for my iPod cable so it can come through the pocket.
    Heres another view
    The shorter leg is about 1/4-1/5 inch too short. I just skipped putting screw in them. They are the bottom legs. You could use some washers and a longer screw I suppose.
    This tab has to be removed from each side as well.
    I didnt close in the sides of the pocket because the mounting bracket is black plastic too so it looks fine.
    And the final product
    This was the most modifying I've ever had to do on a stereo install. If you measure carefully and keep your cuts clean it will turn out nice. Remember to but an equal amount from each side of the pocket or it will be off center.
    As for the wiring harness, it was also a Best Kits brand. The only thing I had to do was attach the red ignition wire to another ignition switched wire. For some reason when I plugged it in, there was no power to the red wire. I tapped into the plug that houses the heated seats (Which I dont have). Otherwise it works fine. Hope this helps. I know I sure struggled with finding any info on it. Good luck!
  3. Remove Advertisements
