| Re: No heat on passenger side!!!! Yea, i forgot to mention where the motor/actuator is... after you remove the center consol its a black sideways pear shaped thing, its located where you can see 1/2 if it, by the "left side glove box center consol area". Pull that cover off (held on by 2 or 3 tabs, it pulls straigh off, if not, put your finger pehind one of the clips to help it off) There is 3 torx screws on the gear box, remove them, do not remove the silver torx screws holding the motor/actuator onto the gear box and follow the directions in my past post for reinstallation. Make sure you new motor/actuator works by unpluging the old motor/actuator, plug in the new one, turn you ignition all the way up to run so the climate control comes on, activate the dual zone, turn the knob left/right of the side your working on to see if the motor/actuator is moving both ways. For reinstallation you only need to install 2 of the torx screws (the one closest to the fire wall and the one on the bottom middle), the hard one half-way behind the radio bezel isn't needed. To reinstall the plastic door arm, line the holes from the door arm up to the dual "bumps" on the motor/actuator and make sure there connected (by "feel", you won't be able to see this visually). sorry for the missing pervious info.
Mike
