02 Sensor question and problems p0133 p0154 - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Cadillac Catera and Cimarron Forum Discussion, 02 Sensor question and problems p0133 p0154 in Past Cadillac Vehicle Discussion; Originally Posted by linopizzolanti The car is used, I bought about three years ago. What happened was I hade the ...
  1. #16
    satse is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    Ann Arbor, MI
    32
    Re: 02 Sensor question and problems p0133 p0154
    Quote Originally Posted by linopizzolanti View Post
    The car is used, I bought about three years ago. What happened was I hade the two previous codes p0133 and p0154, basically saying that the front two sensors were not good. I tried to clean them like someone posted earlier but to no avail. I purchsed two aftermarket ones, universal type for $35 a piece. Cut the old ones out and spliced the new ones in. Cleared the codes and drove around for an hour until chk engine light came back on. took it to autozone and they scanned it. this time $ new codes popped up, the low voltage on all four sensors. I then de-did the wiring again, making sure that I had a tight connection but it didn't change the codes, same codes, low voltage. I did check the fuses in the ECM and they are all good except the one related to the fan. Changed that and now the fan is working like it should but i stll have these codes, low voltage coming up on all four sensors.
    I do hear the pump at start up so i know that is working.
    I am wondering if installing sensors that are not OEM or maybe a wrong sensor will set them all off. I ordered a sensor for the cadillac but i am wondering if maybe the sensor is the wrong kind. Ironically the first two codes, well they are gone. What do u think about the sensors being the wrong ones? Thanks for your help.
    I would highly suggest using quality sensors. $35/ea sounds really cheap. As PEETYZ suggested, the NGK ones at www.summitracing.com will work well. I installed one and have not had any trouble since. It was around $80 and a direct fit. OME was $180 or so for the Bosch. Could be a fault in the wiring harness. If you have the old sensors, pop them in the front again and see if the 4 codes pop up again or just the 2.
  2. #17
    linopizzolanti is offline Cadillac Owners Member
    Jan 2008
    72
    Just purchased two sensors from Summit for 150.33. Direct fit. I will keep you posted as to what happens. Thanks for all your help.
  3. #18
    frank moran is offline Cadillac Owners Fanatic
    Automobile(s): Catera, ..
    Jan 2007
    canton,ga.
    72
    231
    Quote Originally Posted by satse View Post
    This is a good suggestion, you stared out with the two front sensors giving a slow response code, now all 4 are producing codes. To reduce some effort get a known good sensor wiith the pigtail and connector in place, see what you get. One other thought, before the problem started were there any fuel issues, alchohol, water etc., slow response is often related to contamination, vacum leaks, exhust leaks....etc. It is very possible one of the sensors you put in is bad, all the sensors are tied together. The reason I mention the fuel, is that it is very rare both sensors go out w the same problem. Just a thought.
  5. #19
    Jan 2008
    72
    Yeah, I just realized that all i probably had to do was clean them and it would have cleared. I think i might have had a faulty gas cap if you ask me because it started one day when i put bad gas in it.
  6. #20
    PEETYZ's Avatar
    PEETYZ is offline Cadillac Owners Enthusiast
    May 2006
    Ohio
    535
    Hows the new sensors working out?
  7. #21
    Jan 2008
    72
    I have to wait two weeks for them to come in. I will keep everyone posted as to what happens.
  8. #22
    Jan 2008
    72
    Hey everyone: I want to thank everyone that help, with their knowledge and expertise, on helping me trouble shoot my problem and get it fixed. I FINALLY PASSED INSOECTION!!!!!!! tHANKS!!!!!! I finally passed inspection with the new O2 sensors from summitracing. They were a bitch to get in and I did have to wait 2 weeks for them but in the end they were perfect. Each part was $70.00 and it was well worth the wait. Again I thank evryone who helped.
  9. #23
    jo3y is offline Cadillac Owners Member
    Jul 2008
    1
    linopizzolanti do you have that part # for the o2 sencers having the same prob.
    thanks, joey
  10. #24
    bookie0116 is offline Cadillac Owners Member
    Apr 2008
    36
    Quote Originally Posted by ed7092 View Post
    i had the same problem, i found a post here about somebody saying to take the O2 sensors apart and clean them with a spray cleaner i can't remember what i used, but it worked, now i don't have a check engine light and it's been good for 3 months.
    02 sensors? Where are they located so i can clean mines? Could this be the reason my car doesn't start sometimes? My check engine light used to come on and go off frequently. But now it's come on and stayed on.
  11. #25
    Army_MP_From_MO's Avatar
    Army_MP_From_MO is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac
    Mar 2008
    El Paso, Texas, United States
    45
    240
    Bookie,
    Drive it by Autozone and they will read the codes and give you a prinout with the codes and an explanation of the codes.
  12. Remove Advertisements
