cadillac parts
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: coolant leak - drivers side
Old 12-03-07, 11:21 PM
valle1018 valle1018 is offline
Casino Cash: $345
I have a coolant coming from somewhere on the driver side in the rear. It doesn't appear to be the oil cooler or HCV valve or the bypass bridge. Any ideas what else it could be? Please tell me it isn't my head gaskets.
  #2 (permalink)
Old 01-05-08, 05:05 PM
BLK98LAC BLK98LAC is offline
Cadillac(s): 98 catera
BLK98LAC's Avatar
Casino Cash: $250
Re: coolant leak - drivers side
having the same problem with mine.
anybody know what it would be?
i got a guy looking at it and he said it might be some kind of control valve or the HG gone.
it just POURS from the drivers rear of the engine.
  #3 (permalink)
Old 01-05-08, 07:28 PM
frank moran frank moran is online now
Cadillac(s): Catera, ..
Casino Cash: $5071
there is a steel pipe that runs from the center and back of the block just below the bridge over to the pass side, this pipe is about 2in in dia. and has an O ring that seals it to the block, just a thought??? I doubt its head gaskets.... any freese plugs in the area your checking?? you may want to lift the intake and really check the oil cooler, it sits in the block in coolent and is only sealed with RTV, there is also a small coolent hose that runs from the throttle body and attaches to the bridge area??
  #4 (permalink)
Old 01-06-08, 08:44 PM
Boris Boris is offline
Casino Cash: $800
That steel pipe in the rear of the motor is the first thing I would check.
I just took it off my motor today and the o-ring was on it's last legs.
It was just starting to leak in my case and was a pain to track down but since I pulled the motor the repair will be easy.
It's held on with 2 bolts and the o-ring is on the pipe side of the mating surfaces.
  #5 (permalink)
Old 01-09-08, 05:48 AM
ChaticCatera206 ChaticCatera206 is offline
Cadillac(s): Cadillac
Casino Cash: $360
I got the same leak, been trying to track it down for weeks, no luck. So Im going to run some dye through the system and check it with a black light after a day or so.
  #6 (permalink)
Old 01-09-08, 08:28 PM
jebfrank jebfrank is offline
jebfrank's Avatar
Casino Cash: $675
Funny you guys mentioned this, I to think I have a very slow leak comming off the rear drivers side! It appears to leak a little right on the exhaust where the flange is. Please post if someone comes up with a fix.
  #7 (permalink)
Old 02-02-08, 11:30 PM
davessss davessss is offline
Casino Cash: $345
i had the leak runs down the exhaust pipe on the drivers side. i checked the oil cooler, the metal pipe on back, the o-ring and everything is fine. after checking everything found the problem bad head gasket. i hope you dont have the same problem.
i am replacing the engine since i couldnt find a mechanic willing to replace th head gasket. now i am looking for the engine mounts with not very good luck.
  #8 (permalink)
Old 04-04-08, 08:11 AM
livebait livebait is offline
Casino Cash: $360
has anyone found anything out about this leak that randomly cant be found
Tags: , , ,
vB code is On
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
