Catera Radio Problems - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 47
Like Tree4Likes
Cadillac Catera and Cimarron Forum Discussion, Catera Radio Problems in Past Cadillac Vehicle Discussion; Originally Posted by lakesidepark Just an FYI. I actually FIXED my multifunction module. I found that the failure with my ...
  1. #31
    carachase is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Catera
    Aug 2010
    36
    3
    SmileRe: Catera Radio Problems
    Quote Originally Posted by lakesidepark View Post
    Just an FYI. I actually FIXED my multifunction module. I found that the failure with my module was simply poor solder joints.
    10 minutes and a hot soldering iron and I had it fully operational. Take the PCB out of the gray plastic case and inspect the back of the board. Hit all the larger solder joints on the back side of the three relays, and anywhere else that looks discolored.
    May not fix them all but it is cheaper than $85 for the ones that it does fix...and it is a correct fix (not just a patch).
    We recently acquired a 99 cadillac catera, with the same fuel door, trunk, and radio problems. We tried this suggestion on our car and it WORKED!
    We just fixed it and after several on/off, test drives, etc. we have not experienced any problems with fuel door, trunk, or radio! We were able to find the box, and the PCB very easily thanks to you posting the part # on here. My husband hit all the solder joints and re-installed. Thanks so much for your info!!
  2. #32
    Aug 2010
    36
    3
    CoolRe: Catera Radio Problems
    it has been a week and all is good! no more pulling up to the gas pump, opening armrest in backseat, pulling the rope attached inside trunk lid to pop trunk, opening trunk panel and pulling cable to fuel door!! lovin' it !
  3. #33
    Cosmo1 is offline Cadillac Owners Member
    Automobile(s): 2001 catera
    Aug 2011
    70
    1
    I too have a 2001 catera but I can not find the area which contains the K134. I have taken off the side panels and can see the air vent but I do not see the modual. What have I done wrong.
    Thanks
    Dave
  5. #34
    heebee is offline Cadillac Owners Member
    Automobile(s): 2 fleetwoods 1 catera
    Sep 2011
    58
    1
    my mom has a 2000 catera ...been a pretty good car it has 103,000 miles...a few months ago it started having problems ... radio won't work...sometimes... trunk won't open... sometimes...she ran out of gas trying to get home after trying to get gas but not being able to put gas in, cuz gas door would'nt open....so here is a little tip...i noticed that if the radio is not working the clock is not lit up the gas door also the trunk release won't work from inside button... but if i take it out of park ...everything comes back to life....sometimes it dies out again when i put it back in park... but at least i can open gas door ... don't know if it will work on any other car but if u need gas and u r stuck u could try taking it out of park and maybe it will get u down the road....i guess eventually i will try to replace that relay everyone is squak'in about ...
  6. #35
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Is there no manual release for the fuel door in the trunk?
  7. #36
    LVysther is offline Cadillac Owners Member
    Automobile(s): 2000 Catera
    Aug 2013
    1
    Hello. I am new to the forum. I just bought a 2000 Catera and I am having some of these problems listed but I am having my Sport Mode Button kick in by itself. Does anyone think the K134 will fix this problem as well? Thank you.
  8. #37
    CodyCatera is offline Cadillac Owners Member
    Automobile(s): 01' Cadillac Catera
    Sep 2013
    21
    13
    Anyone have a solution for when the rear defrost is on your radio looses signal?
  9. #38
    innocentt702 Guest
    Hello, I am planning on purchasing a 2001 Cadillac Catera with only 87,000 miles on it. But the problem is, the lights on the roof, the radio, the heated seats, only work when car is off. Also, gages stop working all of a sudden, Fuel Sensor says empty when its really not... what could all this be? & would it be expensive to get it all fixed??
  10. #39
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Quote Originally Posted by innocentt702 View Post
    DON'T BUY IT!!!!!! Read the post here. The car is one of the worst made in the last 20 years. An electrical nightmare! It isn't worth 2 cents!
    Read the post to so how problematic it is
  11. #40
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Yes u right. DON'T BUY IT! Unless u works on cars and u will do all job your self.
    Parts cost double of cars like Toyota, Nissan, Mazda, Honda...
    As soon as u fix something, something esle will go out.... im giving up on car, im done fixing it. As soon as I get extra money to put down, im getting me 2014 Camaro. No more used cars..
    By the way my Catera in dealer now for diagnostic, because my rpm and speedometer dont work....
  12. #41
    Lizzys Cat is offline Cadillac Owners Member
    Automobile(s): 2000 Catera!
    Aug 2013
    10
    If you are having the radio issue where it won't power on in position 2 and only key position 1 upon shutdown, check fuse #10 for the aux water pump. This was our issue and not the K134 MF relay.
  13. #42
    Cateraprobs is offline Cadillac Owners Member
    Automobile(s): Catera
    Jan 2015
    Where is this #10 fuse?!? Oarnge relay under hood?? Or inside under dash?
    Quote Originally Posted by Lizzys Cat View Post
    Where is the fuse #10
  14. #43
    elgato is offline Cadillac Owners Member
    Apr 2015
    1
    Not sure if anyone is still reading this old thread but I will post anyway.
    2000 Catera.
    A fully charged battery will drain completely in two to three days if the car is not driven.
    With a meter between the battery and cable it will read about 2.5 after everything settles down. Pulled fuses one by one
    and the Radio/Batt Protect was the only one that made a significant difference. With the fuse out it will read about .2 after it settles down.
    It looks like the circuit designed to protect against battery drain is causing the problem?
    Also,
    Frequently, key on or off, there will be a sound that sounds like a flasher relay ticking. No lights are flashing inside or out when this happens. Is this normal?
    Any ideas?
    Thank You
  15. #44
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    I have the same problem with the battery not holding its charge. Mine is a low output voltage from the alternator of about 11.9 - 12.7 volts according to my Scangauge II. I'm not able to tackle the job of removing and either rebuilding or replacing the alternator myself so I keep recharging the battery overnight every 2 or 3 days. Not the best solution but until I find a garage willing to do the job it'll have to do.
    As for the "clicking sound" I don't have that trouble. My turnsignals make no noise at all when flashing so I don't suspect it could be that circuit. It might be the fuel pump, auxilliary water pumps, or maybe the radiator fans but those are wild guesses. Does pulling fuses cause it to stop?
  16. #45
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Quote Originally Posted by elvin315 View Post
    UPDATE:
    Found a Saab garage familiar with the L81 3.0 V6. Both cars use the same basic engine (the Saab uses it as a 2.5L). The alternator had low output and they replaced it with a new factory part. Output is now 13.2 - 13.5 volts. The big test was last weekend. I had to leave it at the airport for 3 days and normally the battery would be weak, but when I turned the key she started right up. Hallelujah!!!
  17. Remove Advertisements
