misfire mayhem
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, misfire mayhem in Past Cadillac Vehicle Discussion; it is a 98 catera and i just had the valve cover gaskets replaced and when ever i am a ...
    ashe91596 is offline Cadillac Owners Member
    Apr 2004
    35
    7
    misfire mayhem
    it is a 98 catera and i just had the valve cover gaskets replaced and when ever i am a little heavy on the gas from a full stop i get misfires. the misfires stop when i turn off the car and restart. the codes that i recieve are P0300, P0302, and P0305. i just wonder if it is my ignition wires or something else. Oh i also about a week before i got the valve cover gaskets done i had the 246 ignition wires replaced. thanks for any help.
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Re: misfire mayhem
    Quote Originally Posted by ashe91596
    Those codes say you've had misfires in cylinders 2 and 5. Make sure each wire is going to the correct coil @ plug connector. You may need to replace the sparkplugs if that hasnt been done; if there was oil in there the plugs are shot.
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: misfire mayhem
    Oh, and is the check engine light on? That could signify an emissions/engine control problem. Were there any other codes?
    Apr 2004
    35
    7
    Re: misfire mayhem
    the check light comes on when i am too rough with it. and those where the only codes that came up. how hard is it to replace the plugs and what kind should i get? thanks for the help
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: misfire mayhem
    I have yet to change the plugs on mine, so I wouldnt know . But I can tell you that it does require platinum tipped sparkplugs. Id even reccomend going with what they probably have, which is Bosch... or AC Delco if thats the case.
  8. Remove Advertisements
