Stereo Updgrade?
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, Stereo Updgrade? in Past Cadillac Vehicle Discussion; Hello all, I am hoping to add an amplifier and sub to my car while keeping my existing factory system ...
    vogel81 is offline Cadillac Owners Member
    Feb 2004
    Columbus, OH
    35
    92
    Stereo Updgrade?
    Hello all,
    I am hoping to add an amplifier and sub to my car while keeping my existing factory system in place. I have the Bose system which sounds great....just want a little more punch. I am wondering if I am able to use a line level converter in order to get the signal to my amp. I am concerned with this approach due to the Bose system using a different impedance. (I think???) I am wondering if I hooked the line level converter up before the Bose amplifiers, (i.e. directly behind the radio) if it would work, and then I wouldn't have to worry about impedence issues?? Any help would be appreciated.
    mytmous is offline Cadillac Owners Member
    Apr 2004
    Madison, AL
    53
    Re: Stereo Updgrade?
    Just got on here but thought I'd answer, If you use a line level adapter,
    I'd(I'm doing now) use the wires in the trunk, split the ones to the rear speakers, so you still get sound out of them, then use the line level to plug into the amp. Adjust as needed.
    What size you going to? or what are you putting in?
    I'm making a custom fiberglass piece to go where the spare tire is, will most likely use a single 12, audiobahn Flame Q, maybe invert to show off the basket,
    and play up the Chrome. But I'm still working on the design layout for it.
    Feb 2004
    Columbus, OH
    35
    92
    I am also going to design a box to fit. I plan to make a bos that will fit on the left side of the trunk right in front of the spare. I plan to use a Rockford Fosgate 2 channel amp (not my first choice, but I have one laying around) and either a single 10" or 12" JL.
    Apr 2004
    Madison, AL
    53
    Found out on mine, that on the right side I have the CD Changer hook up, so I have my remote turn on source.
    I will now mount the amp in there or on the outside and wire it on the right, run the wires under the trunk carpet to the left side for the box and speaker.
    I'm trying to hide the line converter up in the amp rack and run the wires through the side wall so I don't lose any trunk space.
    Feb 2004
    Columbus, OH
    35
    92
    where did you find the CD changer hookup?? Everything else sounds like it makes sense and good luck with your installation.
    Apr 2004
    Madison, AL
    53
    on my 01 on the right side of the trunk, I opened the little access door like to change the brake light bulb out(which is what I was doing at the time) and sitting there clipped to the fender was the CD changer plug, just waiting to get plugged in.
    Speedingpenguin's Avatar
    Speedingpenguin is offline Cadillac Owners Fanatic
    Nov 2003
    Massachusetts
    29
    222
    thats actually how we found out the car had it! one of the bulbs was flickering a little bit, so we were trying to get to it and we had the cover off inside the trunk and i was like 'You sure this car doesnt have the CD changer?' (this was back like right after my dad got the car in 98), and he insisted that it was just the hook up for it.....we looked at it for a few minutes, pushed the little cover on top to the side and he was like 'Well, I guess it is!'
    Pretty surprising, LOL
    Feb 2004
    Columbus, OH
    35
    92
    I'll have to check it out. I never thought to look for it. I'll see if it's the same for my 99. Thanks.
  11. Remove Advertisements
