'97 Oil Pressure
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, '97 Oil Pressure in Past Cadillac Vehicle Discussion; Can Anyone Tell Me The Normal Oil Pressure For A 97 Catera, Just Bought It Everything Seems Ok, But Oil ...
    mhvfd is offline Cadillac Owners Member
    Apr 2004
    CHARLOTTE
    42
    6
    '97 Oil Pressure
    Can Anyone Tell Me The Normal Oil Pressure For A 97 Catera, Just Bought It Everything Seems Ok, But Oil Pressure Goes Down To Very Low At Idle And Up To 80 On Tghe Hiway, Is This Normal Or Ok?.. Thanks
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Re: '97 Oil Pressure
    How low is low? Did it have an oil change before you bought it? What type of oil was put in it?
    Reguardless, heres vital information for you about oil pressure problems...
    Read it, get to know it...
    http://www.babcox.com/editorial/ar/ar10180.htm
    Could be any one of those problems described for both low pressure and high...
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by mhvfd
    It is normal to have very low oil pressure at idle. If you are not getting an oil pressure warning light then it is fine. The systems are sized correctly for the engine and as a result have very low pressure at idle RPM when hot. Excess oil pressure at idle just wastes energy and costs fuel economy. The engine needs little or no oil pressure at idle so it is not a problem.
