hi my problem is this, a few days ago my catera got a weird problem, the electronic door locks stopped working and the headlights stayed on no matter what. the doors still would unlock and lock, just not with any button, in cluding my trunk which does not have key access, which means that i have to climb into my trunk through the back seat and pull the emergency release to get it open. since i had to work all the time i didnt have time to take it to a shop. i have just been unplugging the negative wire from the battery every time i park the car. but just today i went to plug the battery back in and the alarm started going off and i couldn't get it to shut off unless i unplugged the battery i tried putting the key in the door and trhe ignition and starting the car, both didn't work. please help if you know any reason for these problems, also i dont have an owners manual so if there is a fuse blown, please tell me which one cause i don't know which fuse is which.
never mind, relay and fuse went bad at the same time. go figure. thankfully i figured it out myself and didnt have to pay some ******* 300 dollars to fix it
