Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: GTO Brake SWAP LOG.
  #121 (permalink)
Old 09-27-08, 12:22 PM
Cadillac(s): Cadillac
View Black02SLPSS's Photo Album
Casino Cash: $2910
Re: GTO Brake SWAP LOG.
Out of curiosity...How much different are the bolt patterns between the two? Or is the 04 GTO rotor the same diameter and thickness of the catera rotor?
  #122 (permalink)
Old 09-27-08, 12:35 PM
Casino Cash: $2910
meh new catera rotors are pretty cheap.. ill just buy new ones.
  #123 (permalink)
Old 09-28-08, 12:42 PM
CateraMV6's Avatar
Cadillac(s): Opel Omega
View CateraMV6's Photo Album
Casino Cash: $13287
Talking Re: GTO Brake SWAP LOG.
I think GTO ones are 5x115 or 5x114.3 same as the BMW bolt patterns... M3s in particular...
As for size they are exactly identical with the exception of bolt pattern so I dont see why anyone would even bother with them.... just get a set of OEM ones from the local auto zone and you will be happy, the ones on ebay, are drilled and they can crack especially if you were to use them with the bigger GTO calipers, because you increase clamping forces and those holes when heated stretch out and stress the metal around it and pretty soon they can fail and if that happens at a higher speed you are a dead man...
Also the holes were for decreasing weight and allowing for room for the gases created by the pads to escape but thats a thing of the past the new pads dont gas up so unless you care for looks I would recommend that you stay away from those...
Another thing with sloted rotors is that you loose gripping area where the slots are so its as if you decreased the size of your rotor...
Best braking will be out of Solid Vented rotor, with GTO calipers and C5 pads... Hawk or whatever brand you like...
I got the cheapest money can buy from autozone... C5 Z06 pads and they grip like no other, much much better then the previous GTO pads..
  #124 (permalink)
Old 10-15-08, 05:15 PM
View steinmetz's Photo Album
Casino Cash: $360
Hi, did anyone find out if the c5 caliper will fit the catera? What about the c6 caliper?
And do the gto 05-06 caliper fit on the gto 04 bracket?
  #125 (permalink)
Old 10-15-08, 06:54 PM
Casino Cash: $2910
C5 and C6 calipers are the same. Along with the 05-06 GTO calipers. The mounting brackets are different. Especially on the GTO's. If you want to use the 05 goat calipers you would need to change hubs, which would intail changing wheels to match the new lug pattern. However you CAN use a C5-C6 pad on the 04 Goat caliper and that will give you better braking. I just got a set of 04 GTO calipers and they look identicle to my Camaro SS calipers. Just another piece of info, alot of people on LS1tech do a C5 brake upgrade, however it is also known that the C5 calipers have less clamping pressure than the Fbody calipers due to having smaller pistons. But it is still an upgrade because there is more surface area on the C5 rotor.
  #126 (permalink)
Old 12-04-08, 09:05 AM
CateraMV6's Avatar
Casino Cash: $13287
Not quite the same there are some differences... the C5 are wider becasue the C5 rotor is 1/4" thicker and that will be a problem...
BTW here is my latest research project and a few teaser photos...
I will update on the progress as I install these but from first looks the calipers are totaly different however the piston size is identical so thats good news... but I am affraid that they will sit too far back on the guide pins as the 1/4" has to be absorbed by something... and the pistons will stick out too far and alsmo it makes me wonder whats going to happen when the rotor wears and the pads ge thiner... not sure if its gonna be a safe swap but its worth a try...
  #127 (permalink)
Old 02-12-09, 01:36 PM
eastsidercaddy's Avatar
Cadillac(s): '97 Black Catera
View eastsidercaddy's Photo Album
Casino Cash: $2980
I've got the calipers, bracketes, and lines for the GTO brake upgrade and have everything running smooth. That's until i'm ready to disconnect the brake hose from the bracket on the car. I've never done fluid for brakes, just pads but i have my friends uncle who knows how to do that but i'm confused as hell on how to get the rubber hose from the bracket the screws into the hard line. Somebody please help!! It's probably easier than i'm making it out to be but i'm still learning on things. I know ALOT but this has taken my cake. Thanks
  #128 (permalink)
Old 02-12-09, 03:02 PM
CateraMV6's Avatar
Casino Cash: $13287
Are you talking about the monunt on the body?
If so I think I had to disconnect the Rubber hose from it and reconnect the GTO Hose to the line... I think you need to use line wrenches otherwise you strip the nuts on those brake lines.
  #129 (permalink)
Old 02-13-09, 04:08 PM
Casino Cash: $2980
well i figured it out yesterday. Got some more pics later. This is a great upgrade
  #130 (permalink)
Old 06-15-09, 10:54 PM
View tcklaws's Photo Album
Casino Cash: $250
Do you still have the 04 GTO Calipers? I don't know if the 05 calipers would fit on my 2000 sport or not.
Thanks
  #131 (permalink)
Old 06-15-09, 11:56 PM
CateraMV6's Avatar
Casino Cash: $13287
Thanks
Nope the 05-06 were entirely different, bigger rotors, thicker, more offset, so none of those components will work unless you redrill the GTO rotor, and somehow figure out a way to mount it on your car...
The rotor is the biggest stopper in the whole thing... look for the 04 units, which have a set but they are not ready yet... I will post around when I get them ready to go...
  #132 (permalink)
Old 06-16-09, 02:25 PM
CateraMV6's Avatar
Casino Cash: $13287
Ok, for those of you who have upgraded to stainless steel lines, which ones did you use?
Wilwood dont work they are specific to their calipers, something about the size of the connectors...
There is also stoptech, and baer?
Any links or prices?
  #133 (permalink)
Old 07-10-09, 12:22 PM
Cadillac(s): none
View Kodan's Photo Album
Casino Cash: $2015
My local garage made them for me, front and rear.
Brake Lines are from Goodridge
Peter
  #134 (permalink)
Old 08-30-09, 06:56 PM
Cadillac(s): none
View Q2SUPHOMIES's Photo Album
Casino Cash: $385
2004 gto calipers rotors 250 plus ship
Hello all,
A member let me know you guys are interested in 04 calipers..I just upgraded my car so don't need them. In good shape. PM me...take care..shipping based on location...always try to find the best price for shipping.
  #135 (permalink)
Old 09-08-09, 04:19 PM
Cadillac(s): none
Casino Cash: $385
Bump for 04 brake sale Q2SUPHOMIES
Tags:
brake, gto, log, swap
