Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: GTO Brake SWAP LOG.
  #76 (permalink)
Old 04-17-08, 07:40 PM
elvin315's Avatar
Cadillac Owners Enthusiast
Cadillac(s): Platinum 2001 Cadillac Catera Sport
View elvin315's Photo Album
Casino Cash: $12026
Re: GTO Brake SWAP LOG.
Originally Posted by ariza034 View Post
what is the size of those wheels/tires and do you have a full body shot
Get ready to drool.
  #77 (permalink)
Old 04-17-08, 10:44 PM
CateraMV6's Avatar
Cadillac(s): Opel Omega
View CateraMV6's Photo Album
Casino Cash: $13287
I assume you got those from a European Monaro or something of that sort...? Nice job thou, much better then those old little brakes... Braking is probably improved too... BTW how much Chamber are you running on that thing... it looks way too much... mine is at 2.25deg and they stick out like crazy...
Very nice Stainless Brake lines... and also you painted the control arms... and struts I assume? very cool...
  #78 (permalink)
Old 04-17-08, 11:15 PM
ariza034's Avatar
Cadillac(s): Cadillac Catera Soon CTS
View ariza034's Photo Album
Casino Cash: $4272
17's?x10?
  #79 (permalink)
Old 04-17-08, 11:58 PM
CateraMV6's Avatar
Casino Cash: $13287
Here is another kit that popped up on eBay its just like the pictures posted above... Red/Silver Calipers , hoses included but no pads... those will run you 30-50$ plus you can upgrade to the C5s...
http://cgi.ebay.com/ebaymotors/ws/eB...m=140225634257
  #80 (permalink)
Old 04-18-08, 12:05 AM
CateraMV6's Avatar
Casino Cash: $13287
Elvin may be this will help...
"They won't bolt on directly. While the spacing on the bolts is close, the C5 bolts are 14mm, while the f-body bolts are only 12mm. It *MIGHT* be possible to drill the holes out, but that is NOT recommended. Also, the C5 pistons are SMALLER than f-body pistons. F-body caliper pistons are 44 mm, where as the C5 piston size is only 40.5mmm. Because the C5 rotor is 13" (the f-body rotors are 12") the caliper has more leverage and thus doesn't need pistons are large.
What you can do is convert to C5 front brakes (C5 calipers, rotors, pad bracket, and pads). You need a bracket to bolt the C5 pad bracket onto to. I recommend these: http://www.hotpart.com/index.php?p=show&id=177
They are probably the best brackets on the market: strong and light. With this setup, you will need to run 17" wheels."
and here is a link to the discussion... from LS1Tech.. http://ls1tech.com/forums/showthread.php?t=822098
http://www.gmhightechperformance.com...ade/index.html
  #81 (permalink)
Old 04-18-08, 07:40 AM
Catera's Avatar
View Catera's Photo Album
Casino Cash: $2460
Thank you.
The rims have the size 17x8,5 and 17x10.
The tires 215/40 and 245/35.
Greets
  #82 (permalink)
Old 04-18-08, 09:25 AM
Catera's Avatar
Casino Cash: $2460
edit:
pics of my Omega
http://www.cadillacforums.com/photopost/showgallery.php/cat/500/ppuser/12120
greets
  #83 (permalink)
Old 04-19-08, 04:29 AM
ariza034's Avatar
Casino Cash: $4272
Originally Posted by Catera View Post
wow looks really good what is the offset on those wheels +5?
  #84 (permalink)
Old 04-19-08, 06:55 AM
Catera's Avatar
Casino Cash: $2460
Re: GTO BDie einpresstiefe vorne ist +13. Und hinten ist 0.rake SWAP LOG.
Hi,
the offset is in front +13 and behind 0.
17x8,5 ET 13 215/40
17x10 ET 0 245/35
  #85 (permalink)
Old 04-19-08, 09:24 PM
R-Caddy's Avatar
Cadillac(s): 2 1997 Cateras: black&ocean green
View R-Caddy's Photo Album
Casino Cash: $2935
OK, so to make sure: the C5 front pads will fit the stock rotors and GTO calipers, right? Or do I buy GTO pads? Since I am planning a brake job sometime soon...
Thanks
  #86 (permalink)
Old 04-20-08, 09:38 PM
PEETYZ's Avatar
View PEETYZ's Photo Album
Casino Cash: $1902
C5 pads will work with 04 GTO calipers i have pads for a 2004 zo6 in my 04 gto stoping is noticeably better than with gto pads and if the catera rotor is the same as gto minus the bolt pattern your in great shape to go which i think it is =)
  #87 (permalink)
Old 04-20-08, 10:42 PM
CateraMV6's Avatar
Casino Cash: $13287
The only issue I have heard about is that the C5 pads dont have a clip on the outside pad and they can rattle sometimes... when on the highway and when you are not braking... etc.... so other then that they should and will work and will improve braking even more... but probably not enough to notice...
This might help... http://www.dba.com.au/2006/techdocs/T025.asp
  #88 (permalink)
Old 04-21-08, 02:53 PM
View cateraowner's Photo Album
Casino Cash: $6614
sup guys,
i finally got my self a set of GTO calipers.
now i need to find the a set for slotted rotors and brake pads.
I just want to get some advice from you guys.
first rotors, you guys know where I can get a good set of slittoed and drill ones?
and brake pads. how are organic ones? are they any good?
I was looking at R1 concepts and a set of rotors come to $88 and organic pads for $50
but shipping to canada is $55, so that brings the total to about $200. how does that sound? anyone order their products before?
Thanks for reading.
  #89 (permalink)
Old 04-21-08, 05:49 PM
R-Caddy's Avatar
Casino Cash: $2935
I ordered my 4 rotors and pads from eBay for about $260 shipped from OCAutosports, I think. I just ordered 4 new rotors for my other Cat for $162 shipped from Canada, company GForceBrakes. I used Best Offer at $100, but they declined, then tried $110 and they took it. Shipping + insurance =$52, total $162. And they have the hub area painted black, which I intended to do anyway. Check them out http://cgi.ebay.com/ebaymotors/Magnu...8842QQtcZphoto I will order front and rear pads separately after I get the GTO calipers Totally badass
  #90 (permalink)
Old 04-21-08, 07:34 PM
elvin315's Avatar
Casino Cash: $12026
These are the discs I have on my Cat. Dimples and slots provide escape for gasses and water. The lack of through and through drilling maintains the structural integrity of the disc to reduce the chance of fracturing. Black zinc coated to prevent rust on the unswept areas plus to accent the dimples and slots. They're completely coated when you receive them and it takes a few stops to wear it off the swept area. Makes for some very long scary stops until it's gone. Haven't done the rears yet. They're on the list.
click
Elvin
Tags:
brake, gto, log, swap
