Car drove all day No problems, HAd to buy another used car after my husbands car broke a rocker arm. So bough friends Mercedes 300d. When out next day. NO START. After reading Many posts on NO-starts. I ordered the CPS and is installed. No Start. Checked the the fuse under the dash to the fuel pump, NO Power. Checked the Fuel pump relay. It is not engaging. POwer to one side not the other. I have jumped those pins and could hear the pump pressurize the system. It would hit a cyclinder then die. I then used 2 test lites. One on the relay control one on the pump die wire of the relay. So i was getting power for a moment to the pump for a moment then it turns off again. This did not happen all the time. Whenit did i would get that one cylinder kick then nothing.
So then i barrowed a scanner.....NO CODES....
reset codes, just in case NO codes/No start.
Recharging battery again for further testing.
PLEASE HELP
CATERA- CAT' ERA; German; PAPER WEIGHT.
